Mindumer Posted February 21, 2024 Share Posted February 21, 2024 Using the foot motion to open the trunk is proving difficult for me to master. I stand at the corner of the bumper and wave my leg. It has a 40% success rate in opening. I attempted to understand it but am unable to grasp it. What is lacking? I inquired with the dealer when I had my 2023 vehicle. He recommended that I stand on the back bumper, but that approach is as ineffective. The dealer is around 45 minutes away, and I did not have the opportunity to return there. Link to comment Share on other sites More sharing options...
engrol Posted February 21, 2024 Share Posted February 21, 2024 It was quite effective for me over the summer. Almost every move I made had a 99% success rate in opening and closing the trunk. Pleasant. But as winter arrived, it became a big nuisance. I can only successfully open the trunk of the same automobile 5% to 10% of the time. Each time I identify a correct angle and indicate it, it doesn't function the following day and requires a different angle. I stopped trying since it causes my pants to become soiled when I had to attempt to open the trunk 15 times. I mostly use the remote or trunk button now. I hope everything will return to normal in the summers. The automobile seems to be impacted by a combination of salt, filth, ice, and snow residue, even after being thoroughly cleaned. Link to comment Share on other sites More sharing options...
Videoman Posted February 21, 2024 Share Posted February 21, 2024 I discovered that stepping to the side and kicking vigorously beneath the right or left rear portion reliably triggers it for me. If done correctly, you will likely end up kicking the automobile. Link to comment Share on other sites More sharing options...
Finestey Posted February 21, 2024 Share Posted February 21, 2024 I find it highly efficient and functional 99% of the time. A gentle motion with the foot from the back of the wheel towards the rear causes it to open each time. Link to comment Share on other sites More sharing options...
Mindumer Posted February 21, 2024 Author Share Posted February 21, 2024 I tested it outside and it is not functioning. I will bring it to the dealer for inspection. Lev also reported that it did not function for him during winter. It is now winter in Wisconsin, however the temperature is not extremely chilly at the moment. I had it cleansed and had an underbody flush. Link to comment Share on other sites More sharing options...
engrol Posted February 21, 2024 Share Posted February 21, 2024 Yes, that was my experience before the roads were covered with a mixture of ice, snow, mud, and salt. Now it's more like "kick forcefully and hope your shinbone doesn't fracture." Link to comment Share on other sites More sharing options...
engrol Posted February 21, 2024 Share Posted February 21, 2024 These automobiles are replete with surprises. Today, I was unable to start my automobile due to the notice "refer to handbook. smart key deactivated." I was able to lock and unlock my vehicle with the fob, but I couldn't start it. Researching on Google was beneficial. Lock the vehicle with the key fob, unlock it using the mobile app, and there you have it. You may now proceed to restart the automobile. Simple-minded. The explanation seems to be my action of remotely locking the vehicle using the app last night. I would be unable to resolve this problem without using Google. Link to comment Share on other sites More sharing options...
SushySosa Posted February 21, 2024 Share Posted February 21, 2024 I had the identical problem after locking the vehicle with the InControl app the previous night. The next day, I drove the vehicle, stopped, turned it off, and walked inside a shop. Returned to the vehicle and unlocked it by just bringing the fob close to the car and pressing the handle. Upon attempting to start, the system said that the key had been disabled. After exiting the vehicle, I locked it and attempted to use the key again, but it was disabled. The dealership confirmed that this is an issue. Guided me through the process of locking and unlocking using the app, and after many attempts, the key was reactivated. Link to comment Share on other sites More sharing options...
RosaStyle Posted February 21, 2024 Share Posted February 21, 2024 My device works well about half of the time. My wife acquired a new Q3 and we had a similar situation with it. Link to comment Share on other sites More sharing options...
Ledgerciao Posted February 21, 2024 Share Posted February 21, 2024 This one is quite unusual. With the exception of one of my Rovers, this system works well, activating consistently and effortlessly. One of them fails to activate around 50% of the time, and when it does, it requires many efforts. Link to comment Share on other sites More sharing options...
BizarreBleak Posted February 21, 2024 Share Posted February 21, 2024 I was unable to make it function successfully even once. Now I am questioning if I possess this feature. PHEVs may not possess it. My P550e may not particularly have it. Link to comment Share on other sites More sharing options...
Starat Posted February 21, 2024 Share Posted February 21, 2024 In another discussion, I learned that to access '24', you need to purchase an ATB or a higher level. Link to comment Share on other sites More sharing options...
CrownChikk Posted February 21, 2024 Share Posted February 21, 2024 To access the trunk/cargo space, stand behind the back tyre of the vehicle and kick just behind where the mud flap is located. Give it a kick and wait for 1 second, it often opens. Repeatedly kicking instead of kicking once will result in the process failing. Link to comment Share on other sites More sharing options...
