RosaStyle Posted July 29, 2024 Share Posted July 29, 2024 Greetings, individuals. Could someone kindly provide me with some advise, please? I own a 2004 E53 X5 with an automatic gearbox. The problem is in experiencing intermittent jolts when decelerating while driving. I have been informed that it may be necessary to replace the transfer case fluid due to the car's high mileage of 180,000. Displayed below is a photograph of the recommendation provided to me from my nearby automotive parts retailer. Can somebody provide a recommendation about the use of this fluid on my transfer case, or have I been deceived? Link to comment Share on other sites More sharing options...
RosaStyle Posted July 29, 2024 Author Share Posted July 29, 2024 NOTE - I have inspected the transfer case actuator motor and it seems to be in proper working condition. The gears are undamaged and in excellent shape. Any guidance would be much appreciated. Thank you Link to comment Share on other sites More sharing options...
MamaKiddo Posted July 29, 2024 Share Posted July 29, 2024 I am uncertain about the accuracy of the information, but personally, I would get a litre of DTF from a BMW dealer to ensure with absolute certainty that the proper substance is being used. Link to comment Share on other sites More sharing options...
RosaStyle Posted July 29, 2024 Author Share Posted July 29, 2024 Evidently, this product seemed to be the correct one, but its low price made me sceptical, which is why I enquired. Thank you. Link to comment Share on other sites More sharing options...
Sumoto Posted July 29, 2024 Share Posted July 29, 2024 If the substance is really the appropriate one, then make use of it. The comma is of satisfactory quality. Link to comment Share on other sites More sharing options...
RosaStyle Posted July 29, 2024 Author Share Posted July 29, 2024 Understood. Link to comment Share on other sites More sharing options...
Cleverco Posted July 29, 2024 Share Posted July 29, 2024 To ensure reliability, it is advisable to get one litre of DTF from BMW, as recommended by @MamaKiddo. It is not advisable to take the chance, since damaging the transfer case might result in significant expenses. You will not use the whole litre since it only takes around 850 millimetres. Link to comment Share on other sites More sharing options...
RosaStyle Posted July 29, 2024 Author Share Posted July 29, 2024 That is my current contemplation. This fluid from Comma has the potential to be effective, but there is also a possibility that it might cause damage to my transfer unit. I was hoping to find someone who has experience using this fluid on their transfer case and can provide a testimonial for its effectiveness. Link to comment Share on other sites More sharing options...
Cleverco Posted July 29, 2024 Share Posted July 29, 2024 The issue arises from the significant uncertainty caused by the fact that the before and after facelift transfer instances are fundamentally different. Being a 04 vehicle, you belong to the post facelift category, exactly as mine. This means you have an active multi-plate wet clutch. The oil selection tools may sometimes malfunction and recommend the use of pre-facelift fluid, which may cause damage to a facelift transfer case. The £30 for DTF is not worth risking. Link to comment Share on other sites More sharing options...
Cleverco Posted July 29, 2024 Share Posted July 29, 2024 The shock experienced while decelerating is likely caused by the abrupt transition from second to first gear when the vehicle comes to a complete stop. Unfortunately, all of them engage in this behaviour. The only solution is to rebuild the gearbox mechatronic. The actual reason of the issue is still unknown, however, there are many effective solutions available. These include a software update, replacing the fluid and filter, installing new solenoids, using the updated separator plate, and installing new dampers. Link to comment Share on other sites More sharing options...
RosaStyle Posted July 29, 2024 Author Share Posted July 29, 2024 An acquaintance of mine had the same problem. The application of new liquid resolved this problem. I want to begin the process by doing a fluid change and thereafter assess the outcome before proceeding further. Thank you Link to comment Share on other sites More sharing options...
RosaStyle Posted July 29, 2024 Author Share Posted July 29, 2024 I wholeheartedly agree with your viewpoint. It is not advisable to take such a costly risk. Link to comment Share on other sites More sharing options...
Finestey Posted July 29, 2024 Share Posted July 29, 2024 Has the automatic gearbox been serviced? Worthwhile if not. Link to comment Share on other sites More sharing options...
MagicPod Posted July 29, 2024 Share Posted July 29, 2024 The price for my previous F31 330d xDrive was £30 per litre. I chose to go with BMW since there were too many factors to consider. Link to comment Share on other sites More sharing options...
RosaStyle Posted July 29, 2024 Author Share Posted July 29, 2024 The problem is in the presence of several factors, and it is crucial to avoid using the incorrect fluid that might potentially damage your transfer case. Thank you. Link to comment Share on other sites More sharing options...
RosaStyle Posted July 29, 2024 Author Share Posted July 29, 2024 Negative, the device has not undergone maintenance. I will examine the matter and see what actions may be taken. Thank you. Link to comment Share on other sites More sharing options...
MagicPod Posted July 29, 2024 Share Posted July 29, 2024 Have you explored this website? It has several X owners and a wealth of valuable information. Link to comment Share on other sites More sharing options...
MagicPod Posted July 29, 2024 Share Posted July 29, 2024 https://xseries-forum.com/forum/index.php/board,8.0.html Link to comment Share on other sites More sharing options...
