TypoQueen Posted September 8, 2025 Share Posted September 8, 2025 Greetings to everyone, My vehicle was in the shop for two months, and upon its return, I saw a "auxiliary battery malfunction" notification on the dashboard, leading me to consider that it may need charging or replacement. I assessed the battery's condition, and the voltmeter indicated a healthy charge of 12.6V. Additionally, I connected it to the charger, which displayed a Full Charge status. I connect the automobile to a charger, and it has provided C073300, "Retrieve fault memory from control module."N10 (SAM Control Module) B1E211B The buffer battery is defective. The resistance limit has been surpassed. I have wire brushed the connections, nevertheless the same issue persists. Is the voltage measurement an inadequate indication of the battery's condition, or should I assess other components inside the vehicle? Thank you very much Link to comment Share on other sites More sharing options...
Lemmand Posted September 8, 2025 Share Posted September 8, 2025 Which automobile is it? Is it not possible for it to be the 2008 CLC? I changed the 12 Ah auxiliary battery in my W222 twice due to the same problem code. The old battery exhibited optimal voltage while unloaded; however, when attaching a 21 W bulb, the voltage decreased by several volts (precise values are not recalled). Link to comment Share on other sites More sharing options...
TypoQueen Posted September 8, 2025 Author Share Posted September 8, 2025 I apologize; I need to update my profile to reflect my 2015 E-Class Coupe. I will replace it and see the outcome. Thank you. Link to comment Share on other sites More sharing options...
SilentSpanner Posted September 8, 2025 Share Posted September 8, 2025 The open circuit voltage does not inherently signify a battery's quality. It is necessary to do a load test. Link to comment Share on other sites More sharing options...
TypoQueen Posted September 8, 2025 Author Share Posted September 8, 2025 I will accomplish that! Thank you very much Link to comment Share on other sites More sharing options...
Spiderer Posted September 8, 2025 Share Posted September 8, 2025 Examine your primary 12v battery as well. When my device reached eight years of age, it failed to maintain the auxiliary battery's charge. Link to comment Share on other sites More sharing options...
TypoQueen Posted September 8, 2025 Author Share Posted September 8, 2025 I just changed the primary battery. I am inquiring if the white font 4-digit number located on the center top surface of the battery represents the week and year of manufacture (e.g., 46 15), akin to the etched code on the battery connection of the main battery. I suspect that my auxiliary is the original battery. Link to comment Share on other sites More sharing options...
Spiderer Posted September 8, 2025 Share Posted September 8, 2025 The first character from the left is a letter. It represents a month of the year. A represents January; B denotes February; C signifies March, and so on. The second number from the left denotes the year the battery was sent from the plant. 4 corresponds to 2004, 5 corresponds to 2005, 6 corresponds to 2006, 7 corresponds to 2007, 8 corresponds to 2008, 9 corresponds to 2009, 0 corresponds to 2010, 1 corresponds to 2011, 2 corresponds to 2012, and so forth. Link to comment Share on other sites More sharing options...
Ziinsig Posted September 8, 2025 Share Posted September 8, 2025 Greetings, friend - Did you fix this issue? I have been experiencing the same problem for an extended period. Replaced the auxiliary battery, but it had no effect. Inquiring if it is the primary battery. The Start/Stop feature is similarly nonfunctional. Link to comment Share on other sites More sharing options...
VibrantShin Posted September 8, 2025 Share Posted September 8, 2025 Charge the primary The auxiliary function operates alone while the engine is off. Link to comment Share on other sites More sharing options...
