Shiyardit Posted 17 minutes ago Share Posted 17 minutes ago My 1997 Volvo 940 estate with the 2.3-liter red block engine is for sale. During my drive, the engine suddenly stopped responding, wouldn't turn over, and displayed no rev counter. I suspected a faulty crank position sensor (cps) and replaced it with a new one, but the problem persists. The voltage at the coil pack was zero, so I moved on to the radio suppression relay (RSR), where I found 12 volts at the plug but no current flowing through it. I opened the relay and connected the two ends, but the engine still won't start. I don't have any fuel pump priming. A pulse from the injector is not feeling Unread tacos Devoid of voltage at the coil I think the EZK module or the ECU might be to blame for all these problems happening at once; am I correct in this assumption, and would installing tuning chips solve the problem? The modules should not be replaced. Link to comment Share on other sites More sharing options...
Shiyardit Posted 17 minutes ago Author Share Posted 17 minutes ago https://www.amazon.co.uk/s/?search-alias=aps&field-keywords=Volvo Link to comment Share on other sites More sharing options...
Shiyardit Posted 17 minutes ago Author Share Posted 17 minutes ago Amazon.co.uk : Volvo coil pack Link to comment Share on other sites More sharing options...
Shiyardit Posted 17 minutes ago Author Share Posted 17 minutes ago Amazon.co.uk : radio suppression relay Link to comment Share on other sites More sharing options...
Shiyardit Posted 16 minutes ago Author Share Posted 16 minutes ago Amazon.co.uk : fuel pump Link to comment Share on other sites More sharing options...
Shiyardit Posted 16 minutes ago Author Share Posted 16 minutes ago Amazon.co.uk : EZK module Volvo 940 Link to comment Share on other sites More sharing options...
Shiyardit Posted 16 minutes ago Author Share Posted 16 minutes ago Amazon.co.uk : volvo ecu Link to comment Share on other sites More sharing options...
Tearcarl Posted 16 minutes ago Share Posted 16 minutes ago Like the850, does it feature a fuel pump relay? Our 1997 850 turbo just went through this. Luckily, I had an extra relay on hand, and it appears to have resolved the issue. Link to comment Share on other sites More sharing options...
Finestey Posted 15 minutes ago Share Posted 15 minutes ago Under the hood, you should find the fuse box. I don't know much about 940s, but they're around the same year as my brother's 1991 760 and my own 1990 240. When our mega-fuse (75 amp, I believe) blows, it cuts power to nearly the entire vehicle. (I had the same experience last year.) Your Volvo might be identical to the one you got because the company is very habitual and uses economies of scale. Before you start throwing money at it, make sure that. Link to comment Share on other sites More sharing options...
MaxiBroadway Posted 14 minutes ago Share Posted 14 minutes ago It can't be a '97 in the US; 1995 was the last year for that. Look at the letter that comes after the tenth digit of the vehicle identification number; for example, a "R" for a 1994 and a "S" for a 1995. Their stay was limited to the years 1991–1995. Pretty much every time the pump isn't turning on, the fuel pump relay in the fuse box is to blame. If you take the relay out of the fuse block and jump the pins 30–87/2, you can check if the problem is with the relay or something else. At all times, pin 30 is hot in the diagram picture. Never got around to editing and posting the video I shot of disassembling mine and reflowing the solder joints; it worked like a charm and hasn't given me any trouble since. If you want to see the white cover and the orientation of the pins, here are a couple pictures for you. Link to comment Share on other sites More sharing options...
depofly Posted 14 minutes ago Share Posted 14 minutes ago Due to its VIN specificity, it is the ECU that requires rebuilding instead of replacement. Link to comment Share on other sites More sharing options...
Radiantecon Posted 13 minutes ago Share Posted 13 minutes ago We replaced the ignition switch and nearly every other component in the fuel and ignition system of my 1988 740, but the coil remained unreplaced. Link to comment Share on other sites More sharing options...
Finestey Posted 13 minutes ago Share Posted 13 minutes ago It would be highly advantageous to conduct tests to determine if fuel or TIMED ignition is missing in this case. Link to comment Share on other sites More sharing options...
