2015 428i M Sport Coupe shock absorber
TigerDrummer
Greetings, everyone.
I just acquired a 2015 428i coupe M Sport. It need a replacement offside rear shock absorber. I presume the M Sport suspension differs from the ordinary suspension. Could anybody provide recommendations for quality aftermarket shocks? Is it beneficial to replace both rear components simultaneously? I have contacted many locations, and they seemed to have difficulty locating the appropriate component. Does anybody possess the relevant component number? The vehicle has received the M Sport brake update, and I am unable to locate the appropriate pads required for both the front and rear. Does anybody have recommendations for suitable aftermarket brands? I am uncertain about the specific component numbers.
Any assistance would be much appreciated.
Wishing you the best
My E91 originally had Sachs under the MSport specification. I replaced them with Bilstein B4 as an OEM-spec substitute when they need replacing, and they perform well, similar to the original Sachs.
I conducted extensive research and verification of component numbers to ensure their equivalence to Msport specifications, since they vary from SE specifications.
