Markwe Posted December 6, 2024 Share Posted December 6, 2024 A 2011 Orlando 2.0 VCDi 163 is displaying three fault codes: P0101, P0796, and P0700, and consistently enters limp mode. Is anybody aware of what these are and if they can be easily repaired? Thank you in advance. Link to comment Share on other sites More sharing options...
Ledgerciao Posted December 6, 2024 Share Posted December 6, 2024 All three codes you mentioned are established subjects on this Forum and may be accessed using the Search feature. They may also be located via internet search engines, such as Google, using the query 'GM Diagnostic code ****'. P0101 pertains to the Mass Air Flow sensor or air filter; P0700 is associated with the Transmission Control Module; P0796 concerns a transmission solenoid, often linked to automatic transmission vehicles. You did not provide enough car data to determine whether yours is automatic. This information is crucial to understand. If so, there is a significant likelihood of insufficient ATF (Automatic Transmission Fluid) or the fluid present in the 'box' is aged, degraded, and depleted. This may be impacting the gearbox solenoid (P0796); thus, I recommend having your technician replenish the gearbox fluid. If it has not been replaced since 2011, since there is no service history provided, consider having the whole gearbox cleansed and refilled. P0700 TCM may only be a 'sympathy' code produced by the ATF condition. The P0101 code, indicating a malfunction with the Mass Air Flow sensor or maybe a clogged air filter, can be readily rectified by cleaning or replacement. I see no direct correlation between P0101 and the other two, which pertain to transmission issues. My comprehensive evaluation of P0101 and P0700 suggests that the car may possess a substandard service history. To summarise, you may review the current conversations on all three codes by use the Forum Search feature. This will provide you with some context. Secondly, kindly review your Sign-Up and finalise the sections regarding your World Location, which the Forum system identifies as the UK, and complete the vehicle details section (preferably the 'Footer' option) as it allows for more comprehensive information about the vehicle, including gearbox type, mileage, duration of ownership, and service history, among other details. Link to comment Share on other sites More sharing options...
Markwe Posted December 6, 2024 Author Share Posted December 6, 2024 Thank you for your assistance; I will complete the data promptly. Link to comment Share on other sites More sharing options...
Ledgerciao Posted December 6, 2024 Share Posted December 6, 2024 Understood, I will entrust it to you. My post #2 included enough information to absorb. Reviewing previously uploaded subjects will resemble assembling parts of a jigsaw puzzle for you. Link to comment Share on other sites More sharing options...
Sumoto Posted December 6, 2024 Share Posted December 6, 2024 My 2017 Chevrolet Orlando 1.8 LS is experiencing issues with the infotainment system; first, the volume control panel became unresponsive, and subsequently, the whole system intermittently powers on or remains off upon engine start. What may the issue be? Link to comment Share on other sites More sharing options...
Ledgerciao Posted December 6, 2024 Share Posted December 6, 2024 I am perplexed as to why you have placed an infotainment/radio inquiry under the topic heading of Orlando Fault Codes. The current conversations are irrelevant to your topic query. There are ongoing debates about Infotainment in the Orlando Forum that may be beneficial to review in case your answer is already archived. Although you have mentioned your car model in your message, it is beneficial to include this information in the car specifics section, as well as your geographical location, in the appropriate fields during the Sign-Up procedure, which you left incomplete. The Forum system posits that your location may be Namibia. The next link will elucidate the functioning of the Forum and guide you in utilising the Advanced Search feature to investigate and peruse previous postings that may be beneficial to you. Link to comment Share on other sites More sharing options...
Ledgerciao Posted December 6, 2024 Share Posted December 6, 2024 The succinct response to your inquiry is a variety of possible reasons. You do not provide guidance on whether you have conducted any preliminary inspections; nonetheless, components like fuses and fuse holders have to be examined for corrosion. A potentially frayed wire under the dashboard panel. A potentially loose connecting block. An unsuccessful earth connection. Alternatively, there may be an inherent malfunction of the Infotainment, Radio, or Satnav system. In the absence of other information, you may need to seek the expertise of an automobile audio professional. Link to comment Share on other sites More sharing options...
