Brake master cylinder for E34 540i
WannaVulture
My 1994 E34 540i has a brake master cylinder that is experiencing a little leakage, causing a delay in passing the MOT inspection.
Surprisingly, the brake master cylinder (part number 34311163924) is no longer available.
The available alternatives seem to be limited to:
    Locate a pre-owned one (which has presented challenges)
    Reconstruct the current unit.
Online, there are rebuild kits available from FRENKIT. Additionally, I have received assistance from a member of a US Forum who provided specific information on gasket and seal sizes. However, I am uncertain about the next steps to take.
Are there any firms specialising in rebuilding vehicles in the UK? I just relocated here and am specifically looking for companies or forum users that have E34/E32 cars that are being dismantled and have relevant parts available.
Thank you in advance!
I appreciate the provided hyperlink. I was uncertain about the nature of Bigred, but it seems that I have purchased one of the final kits, with the expectation that it would be compatible. I would rather undertake the task of reconstructing myself, while I am aware that there is a possibility of making mistakes in the process.
I have examined this website that discusses a comparable reconstruction:
http://bmw8.us/Brake Booster Rebuild.htm
The individual mentioned in the article explained the technique as follows: "To remove the bakelite bushing, a small hole is drilled near the rear end of the input shaft, allowing it to be pulled out using a wire hook." Detach the circlip and apply WD40. Additionally, there is a vertical pin located underneath one of the reservoir sockets that must be removed since it secures the pistons in place. Appears to be really overwhelming.
It is exasperating to go through this process just to end up having to sell the 540.
Before purchasing a rebuild kit, it is advisable to disassemble the master cylinder and assess its suitability for rebuilding. If there are any marks or damage in the cylinder's bore, it is not salvageable.
Although not ideal, purchasing a used OEM part is a more cost-effective option compared to buying a new one when they were still being produced. Additionally, it is preferable than owning a low mileage 540 that cannot pass the MOT or be sold. I am apprehensive about scoring and damaging any internal components, thus I am inclined to use PastParts.
I appreciate the provided hyperlink. I was uncertain about the nature of Bigred, but it seems that I have purchased one of the remaining kits, with the expectation that it would be compatible. I would rather do the task of rebuilding my automobile myself, since I am used to performing most of the maintenance work on my vehicles. However, I am aware that there is a possibility of making mistakes and perhaps worsening the situation.
