There is an electrical malfunction with Fuse 25.
MundeDas
Hello everyone, I am wondering if anybody can assist me. After experiencing a leak in my vehicle and thoroughly drying everything, an electrical issue has emerged, resulting in warning lights being on. This issue occurs only when fuse 25 is inserted and my radio is turned on. The radio exhibits intermittent on-off behaviour, while the dashboard lights flicker and produce a beeping sound. If the radio does not work when the fuse is blown, I would appreciate any advice on the possible cause of this problem. How can I rectify the issue?
The device is specifically designed for radio use, and it has a screen. The iDrive is the system responsible for controlling various electrical functions in the vehicle. When the fuse is removed, there are no electrical problems. However, when the fuse is reinserted, an electrical fault occurs. This fault causes the radio to switch off and on, and the lights on the dashboard to flicker.
I believe that the version of the software I am using will need coding.While I have a suspicion that the problem lies not with the head unit itself, but with the fuse box, specifically the live connection on fuse F25 is creating the issue inside the box.
