The E91 vehicle's Dynamic Stability Control (DSC) system often engages under regular driving conditions.
Hypabl
The DSC lights have begun to illuminate, and I experience a momentary loss of power during regular driving. Initially, there were just a few isolated incidents of encountering a roundabout, but last night on the road, the warning lights on my vehicle were blinking rapidly, like a brightly lit Christmas tree, even though I was driving on a straight path.
Based on my research, it seems that the problem may be related to a reluctor ring.
I have many inquiries, then.
The problem arose the day after my vehicle's maintenance, during which two fresh rear tyres and brake pads were installed. Could this plausibly be the cause or is it really a chance occurrence?
Can I resolve this issue independently using a Haynes manual or instructional videos on YouTube?
Am I pursuing the incorrect course of action?
Salutations!
Indeed, it seems to be indicative of a malfunctioning ABS sensor or reluctor ring.
Do all the tyres installed have the same rolling radius as the front tyres, meaning they have the right width, profile, and pressures?
Ah, tyres are a wise suggestion, thank you.
The current tyre size is 225/45/ZR17.
The new rear tyres have a size of 255/40/ZR17.
My knowledge regarding tyres is limited. Will the difference between the 45/40 measurements cause any problems?
Undoubtedly, the artefact in question is the relic or ring. If you remove the wheel speed sensor, you will see signs of wear at the end where the ring has rusted, enlarged, and is causing the sensor to deteriorate.
It is coincidental that I have had the same difficulty in the last several weeks. The symptoms are same and may be resolved by disabling the DTC.
Kindly inform me of your progress in resolving this issue. πŸ‘
The reluctor ring and sensor tip will experience wear and tear.
My BMW e90 is equipped with the same tyre configuration as yours, which consists of 225x45x17 tyres in the front and 245x40x17 tyres in the rear. I have never had any issues with this arrangement, and I had the same tyre combination on my previous BMW e46 as well.
