Finestey Posted April 4, 2024 Share Posted April 4, 2024 Is there a procedure to cleanse the chasses and meticulously clean the components located below the suspension? Today, I removed a wheel and saw that it seems to be soiled, like the appearance of a vehicle that has been driven. Has anybody completed a comprehensive whole body cleansing? Link to comment Share on other sites More sharing options...
Thenornpo Posted April 4, 2024 Share Posted April 4, 2024 I used cloth scraps and a degreaser including citrus extracts. Link to comment Share on other sites More sharing options...
Finestey Posted April 4, 2024 Author Share Posted April 4, 2024 Have you detached the wheels? Alternatively, find a solution that bypasses the issue. Link to comment Share on other sites More sharing options...
Thenornpo Posted April 4, 2024 Share Posted April 4, 2024 The wheels were detached to provide access for manual labour. πͺ Link to comment Share on other sites More sharing options...
Bridgenix Posted April 4, 2024 Share Posted April 4, 2024 I recently accomplished this task with exceptional outcomes. Essentially, I removed the wheels and used a high-pressure water spray to clean the areas where the wheels are attached and the components that support the vehicle's weight. Subsequently, I applied a specialised cleaning solution to all visible parts. After allowing it to soak, use a tiny detailing brush to vigorously stir everything and thereafter rinse off. Additionally, apply a vinyl protectant to the wheel wells to enhance their shine and provide long-lasting protection. Link to comment Share on other sites More sharing options...
Finestey Posted April 4, 2024 Author Share Posted April 4, 2024 Thank you. Link to comment Share on other sites More sharing options...
Jollyno Posted April 4, 2024 Share Posted April 4, 2024 During the winter, I took off all the wheels and saw that a significant number of the Torx bolts securing the liners were showing signs of corrosion. I have disassembled all of the bolts. The pair had to be extracted using a drilling technique, followed by a thorough cleaning of the affected area. Additionally, some components were treated with silicone grease. The accumulation of leaves between the front liner and the vehicle body on my Gen 1 was rather remarkable. I thoroughly cleaned, painted, or replaced all the torx bolts and gained a wealth of knowledge about the automobile, which was quite pleasant. An additional benefit is that you may subsequently refine the braking discs that encircle the hubs. **** I always use two trolley jacks while removing the wheels, whether from the front or back. Additionally, I always position one jack on the central jacking point, using the VW tubular rubber pad adapter. It provides both insurance and a sense of security. I have discovered that Jack stands are too elevated for raising one side, resulting in instability of the jacks and the automobile. By using two jacks, the pressure is evenly distributed, and you only need to elevate the vehicle to a sufficient height to lift the wheels off the ground. Link to comment Share on other sites More sharing options...
Finestey Posted April 4, 2024 Author Share Posted April 4, 2024 That seems impressive. I am eager to address this promptly. Link to comment Share on other sites More sharing options...
Liveek Posted April 4, 2024 Share Posted April 4, 2024 Designed for the purpose of cleaning the undercarriage and wheel wells. I suggest use a robust rigid brush with these products: Subsequently, apply this as a protective coating using an oil-based preservative: Link to comment Share on other sites More sharing options...
Finestey Posted April 4, 2024 Author Share Posted April 4, 2024 Will the oil-based protectant not attract dirt? Link to comment Share on other sites More sharing options...
Liveek Posted April 4, 2024 Share Posted April 4, 2024 No, you apply the spray generously, allow it to sit for 5-10 minutes, and then remove any remaining residue. Allow a 12-hour period for the substance to completely seal before operating a vehicle, as it effectively repels dirt. As water comes into contact with it, the water forms into droplets and slides off, carrying away any dirt or debris. Link to comment Share on other sites More sharing options...
Jollyno Posted April 4, 2024 Share Posted April 4, 2024 Excellent... I want to using that product in the future. π Link to comment Share on other sites More sharing options...
Finestey Posted April 4, 2024 Author Share Posted April 4, 2024 I will attempt it. Thank you one again. Link to comment Share on other sites More sharing options...
