AmericaMonster Posted March 18, 2024 Share Posted March 18, 2024 I am unable to use a spanner to remove the plastic cover on this injector. I would appreciate your assistance. Link to comment Share on other sites More sharing options...
Captiva Posted March 18, 2024 Share Posted March 18, 2024 Invert the pipe at the other end and extract the pipe containing the injector. Regardless, you will need to reverse the other end as the pipe will not deform enough to remove the injector. Once the head is removed, it will be possible to attach a spanner to it without any obstruction. Link to comment Share on other sites More sharing options...
AmericaMonster Posted March 18, 2024 Author Share Posted March 18, 2024 Thank you, I had already largely undone the other end, but I was still encountering difficulties. I attempted to use an 18 and successfully reversed it, but I am uncertain about my ability to securely fasten it due to frequent slippage and near-rounding of the nut. Should I insert an object into the hole after removing the injector to avoid the entry of dirt and metal shavings into the cylinder, since I will be using a seat cutting tool? Thank you. Link to comment Share on other sites More sharing options...
MundeDas Posted March 18, 2024 Share Posted March 18, 2024 Crowsfoot Link to comment Share on other sites More sharing options...
Talentrews Posted March 18, 2024 Share Posted March 18, 2024 It is advisable to apply a generous amount of spray oil onto the cutting tool and thereafter remove and clean each turn or two. This practice helps prevent the accumulation of shavings on the tool, ensuring that they can be easily retrieved and do not impede the functionality of the cutter. Link to comment Share on other sites More sharing options...
Cleverco Posted March 18, 2024 Share Posted March 18, 2024 Contrary to popular belief, an injector pipe socket effectively performs its intended function. Link to comment Share on other sites More sharing options...
Bitxx Posted March 18, 2024 Share Posted March 18, 2024 Similar to this, there are other varieties available. Link to comment Share on other sites More sharing options...
engrol Posted March 18, 2024 Share Posted March 18, 2024 This is my previous year's activities. Link to comment Share on other sites More sharing options...
