Wordcar Posted February 5, 2024 Share Posted February 5, 2024 Greetings, I have just taken possession of my GTline S hybrid Sportage. Can the USB ports in the chairs be permanently enabled? If a certain option is not available in the menu system, would it be possible for a major dealer to do the task? Thank you in advance Link to comment Share on other sites More sharing options...
Racerse Posted February 5, 2024 Share Posted February 5, 2024 From a physical standpoint, it is technically feasible to connect the HEV battery to the fuse box via cabling. However, it is important to note that if any devices are left plugged in, the minimal 12v capacity of the HEV battery would be quickly depleted. I found that a Dash Cam that is hardwired may operate continuously for 24 hours without any issues, however any device with a larger amperage will definitely not function properly. What you are asking is if a rechargeable battery pack with a capacity of 20000 or 30000 mAh will be sufficient to connect the device, and then you can just bring it inside to recharge it from time to time. Link to comment Share on other sites More sharing options...
Wordcar Posted February 5, 2024 Author Share Posted February 5, 2024 Greetings, I appreciate your prompt reply. The burden is minimal, consisting just of a compact MiFi device (a local internet hotspot). The indentation on the passenger 🚢 headrest provides an optimal location to insert the gadget, and the adjacent USB C connector would be an appropriate power source for it. Are those ports physically connected or controlled by software? Link to comment Share on other sites More sharing options...
Racerse Posted February 5, 2024 Share Posted February 5, 2024 I would presume that they are physically connected.... Link to comment Share on other sites More sharing options...
Wordcar Posted February 5, 2024 Author Share Posted February 5, 2024 Indeed, I am optimistic about it. Link to comment Share on other sites More sharing options...
Racerse Posted February 5, 2024 Share Posted February 5, 2024 Based on the fuse diagram, the devices are regulated by Module 2 in the fuse box, which is safeguarded by a 15amp fuse. This module also governs the wireless charging pad. Link to comment Share on other sites More sharing options...
Shadesmo Posted February 5, 2024 Share Posted February 5, 2024 Although they may be hardwired, they will ultimately be controlled by software. Link to comment Share on other sites More sharing options...
Wordcar Posted February 5, 2024 Author Share Posted February 5, 2024 Indeed, it aligns with my anticipated outcome. It would be advantageous to have access to the software. Link to comment Share on other sites More sharing options...
AmericaMonster Posted February 5, 2024 Share Posted February 5, 2024 I fail to get the rationale for want an always activated hotspot, however: Can you connect the gadget to a portable power bank and then connect the power bank to charge from the seat? While the automobile is not running, the gadget is connected to the battery pack. While the automobile is running, the gadget is connected to the car's battery pack, which is now being recharged by the car. Link to comment Share on other sites More sharing options...
VibrantShin Posted February 5, 2024 Share Posted February 5, 2024 I doubt it is possible, but my concern would be that while the gadget may need little power, if someone else connects another device, such as a screen, it might drain the battery completely. Include the rationale for keeping the automobile operational in the absence of any occupants. If you are leaving someone in the vehicle, activate the ACC mode by pressing the stop/start button without applying pressure on the brake pedal. Link to comment Share on other sites More sharing options...
Wordcar Posted February 5, 2024 Author Share Posted February 5, 2024 I appreciate your suggestion about the battery pack. Additionally, any additional constructive remarks would be appreciated. Best wishes to everyone. Link to comment Share on other sites More sharing options...
