Finestey Posted 53 minutes ago Share Posted 53 minutes ago 2009 Corolla that makes a lot of noise and has a rocky start. It starts up easily and runs smoothly after that. My guess is that this is something. I've thought about trying different plugs, but I'm still not sure if the fuel pump is the culprit. Link to comment Share on other sites More sharing options...
Tearcarl Posted 53 minutes ago Share Posted 53 minutes ago What are the ECM codes? Link to comment Share on other sites More sharing options...
Tearcarl Posted 52 minutes ago Share Posted 52 minutes ago absence of codes Link to comment Share on other sites More sharing options...
Tearcarl Posted 52 minutes ago Share Posted 52 minutes ago 🥲 Link to comment Share on other sites More sharing options...
Micobe Posted 52 minutes ago Share Posted 52 minutes ago To check if the spark plugs are in good working order, remove them. Take a look at the power source and battery. When starting a car with a weak battery, a lot of power is required from the alternator—power that the engine needs to run well—after the car has started. Link to comment Share on other sites More sharing options...
