Sumoto Posted February 27 Share Posted February 27 I had a beautiful spark, forgot to unplug the battery, touched the socket to the positive terminal of the alternator, and now there is no electricity. Is this related to what I observed when I peered under the white cover of the engine bay? All I could find was a small black box. Otherwise, how can I find it? I can't seem to locate them, even though I've obviously blown a big fuse. Even on the battery, I don't see any. Link to comment Share on other sites More sharing options...
Sumoto Posted February 27 Author Share Posted February 27 A multimeter reading of 0.15 volts was obtained when connected to the positive battery post under the hood with ground. Link to comment Share on other sites More sharing options...
Videoman Posted February 27 Share Posted February 27 Was the relay removed from its housing? The distribution board needs to be changed because the fuse inside has probably blown and cannot be replaced. Link to comment Share on other sites More sharing options...
Sumoto Posted February 27 Author Share Posted February 27 I got lucky, therefore it doesn't matter. The vehicle started up immediately after I reconnected the negative battery post. Link to comment Share on other sites More sharing options...
Micobe Posted February 27 Share Posted February 27 Link to comment Share on other sites More sharing options...
Bitxx Posted February 27 Share Posted February 27 Magical. Link to comment Share on other sites More sharing options...
Sumoto Posted February 27 Author Share Posted February 27 Alright, so we can inject some serious learning into this thread by pretending it didn't reanimate in the same way it did. The large fuses that I thought were stored behind the white box in the engine compartment are nowhere to be seen. And here I was thinking there were some on that item about the battery distribution cap? Link to comment Share on other sites More sharing options...
Videoman Posted February 27 Share Posted February 27 They are not replaceable but can be accessed by unclipping the red plastic from the battery's distribution board. Link to comment Share on other sites More sharing options...
Micobe Posted February 27 Share Posted February 27 Is the vehicle still functional? Is it possible for you to check for error codes and remove them? Link to comment Share on other sites More sharing options...
Bitxx Posted February 27 Share Posted February 27 If anything, it is a valid point up there. Lights everything; locks. Link to comment Share on other sites More sharing options...
Sumoto Posted February 27 Author Share Posted February 27 Okay, so there was absolutely no electricity there. Zero. None. Link to comment Share on other sites More sharing options...
Bitxx Posted February 27 Share Posted February 27 Potentially a pyro fuse in the red distribution block. Link to comment Share on other sites More sharing options...
