BizarreBleak Posted November 14 Share Posted November 14 I have substituted the engine loom and verified all fuses and relays, all of which are functioning properly. The engine fails to ignite. The starter activates as though attempting to rotate the engine but fails to persist. The engine can be manually rotated via the pulley, indicating it is not seized. I connected to Ista, which displays many problems; upon clearing, some reappear while others do not. However, I am confident it should still start regardless. I am currently perplexed. I have also replaced the DDE relay. Requesting assistance, if possible. Link to comment Share on other sites More sharing options...
KnightNewscast Posted November 14 Share Posted November 14 It may be a defective ground strap or a malfunctioning starter motor. Link to comment Share on other sites More sharing options...
BizarreBleak Posted November 14 Author Share Posted November 14 I have verified them, and they are both satisfactory. The starter rotates unimpeded when linked to an energised wire. It also participates in the flywheel. Link to comment Share on other sites More sharing options...
Tearcarl Posted November 14 Share Posted November 14 Is the battery still robust after being allegedly unused for an extended period? Link to comment Share on other sites More sharing options...
BizarreBleak Posted November 14 Author Share Posted November 14 The battery is completely charged. The vehicle was in continuous operation until the loom malfunctioned. Link to comment Share on other sites More sharing options...
Mantelle Posted November 14 Share Posted November 14 It appears to resemble a depleted battery. Link to comment Share on other sites More sharing options...
BizarreBleak Posted November 14 Author Share Posted November 14 The battery was completely charged as we awaited the arrival of the new loom. Link to comment Share on other sites More sharing options...
