Thenornpo Posted October 1, 2025 Share Posted October 1, 2025 Hello everyone, I want assistance in indemnifying the engine code for my 2013 520d, which requires replacement. The chassis number is WB5AC32060D629926 Can somebody provide guidance? Thank you in advance Link to comment Share on other sites More sharing options...
Lemmand Posted October 1, 2025 Share Posted October 1, 2025 N47d20c must originate from the F series due to discrepancies between engines in the older E series vehicles. Link to comment Share on other sites More sharing options...
Lemmand Posted October 1, 2025 Share Posted October 1, 2025 https://www.ebay.co.uk/itm/326777254785?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=8xMc12cKTTW&sssrc=4429486&ssuid=eVPsP3o3TNu&stype=1&var=&widget_ver=artemis&media=COPY Link to comment Share on other sites More sharing options...
Lemmand Posted October 1, 2025 Share Posted October 1, 2025 Ensure it originates from a 20d rather than an 18d Link to comment Share on other sites More sharing options...
Thenornpo Posted October 1, 2025 Author Share Posted October 1, 2025 Thank you. Link to comment Share on other sites More sharing options...
Thenornpo Posted October 1, 2025 Author Share Posted October 1, 2025 Greetings, I have received an offer for a fully operational automobile. My vehicle is a 2013 Euro 6, whereas the donor car is a 2010 Euro 5. Will this engine be compatible with my turbo, manifolds, and other components? Link to comment Share on other sites More sharing options...
Lemmand Posted October 1, 2025 Share Posted October 1, 2025 Is the whole vehicle identical in form to the F10/F11 model you possess? Link to comment Share on other sites More sharing options...
Thenornpo Posted October 1, 2025 Author Share Posted October 1, 2025 Both are F10 and identical in form. Link to comment Share on other sites More sharing options...
Lemmand Posted October 1, 2025 Share Posted October 1, 2025 The fundamental engine will remain unchanged; you will just need to transfer your ancillary components. Link to comment Share on other sites More sharing options...
Thenornpo Posted October 1, 2025 Author Share Posted October 1, 2025 Thank you for your assistance. Link to comment Share on other sites More sharing options...
Lemmand Posted October 1, 2025 Share Posted October 1, 2025 Out of inquisitiveness What is the issue with your engine? Ensure that you replace the chains before to installing the replacement, as you would like not to remove it later for this purpose. Link to comment Share on other sites More sharing options...
Thenornpo Posted October 1, 2025 Author Share Posted October 1, 2025 Initially, it displayed a drivetrain warning; I replaced the exhaust pressure sensor. Subsequently, it began emitting smoke, and the AA diagnosed a turbo failure, which I replaced. Five miles later, it started producing banging sounds from the bottom end. Link to comment Share on other sites More sharing options...
Lemmand Posted October 1, 2025 Share Posted October 1, 2025 This issue is rather prevalent in N47 and N57 engines, regrettably. I now own an F15 40d with a malfunctioning bottom end. Link to comment Share on other sites More sharing options...
Bitxx Posted October 1, 2025 Share Posted October 1, 2025 The engine code is N47D20C. Link to comment Share on other sites More sharing options...
