2014 F31 335D uneven acceleration
Meltarb
I have seen that the acceleration has become irregular. There are little obstacles along the way. It continues to accelerate as expected. It becomes more apparent with aggressive acceleration. It is not synchronized with the gear shift.
I have no warning lights or problems on the dashboard, and I have performed a code reading with no apparent issues.
Could it be a warped or deformed alloy due to the many potholes?
What are the service and oil change requirements for the gearboxes and differentials, and what are the recommended intervals?
Thank you for your assistance.
Variations in tire tread depths exceeding a few millimeters between the front and rear tyres, as well as between tyres on the same axle, may lead to comparable troubles, since the transfer box is adversely affected by such discrepancies.
As previously said, it seems to be connected to the transfer case. What is the make of the tires? Is everything from the same brand? What are the tread depths on each axle? Numerous factors must be taken into account, and the transmission requires servicing every 40,000 miles; the gearbox is similar, but it depends on driving habits.
Tyre brand: Michelin; Front tyres: Pilot Sport 4S
Rear - Pilot Sport The front and back were replaced within six months of one another and are around one year old.
5-6 mm of tread left on all tires.
