Removal of paint spots
PopeyeR
Hello, I am seeking suggestions on how to effectively remove little blemishes of white paint on my vehicle. There are sporadic blemishes present throughout the paintwork, and I am uncertain of the cause previous to my purchase. I attempted to use a Dual Action (DA) polisher while using Meguires ultimate compound as a component of my procedure to eliminate swirl marks. However, this endeavour did not provide significant results.
The answer will heavily rely on the specific sort of paint, which I acknowledge may be difficult to determine. If the substance is automotive paint, you may effectively remove it by using thinners on a cloth, but this will also strip away any wax present. However, if it is house gloss or another kind of paint, you may need to seek a stronger solution. Highly skilled detailing professionals will arrive shortly!
Thank you. I apologise for not mentioning in the original article that the substance in question seems to be white house paint or a similar one. It is quite unlikely that the substance causing the spots is automobile paint. However, removing these spots may require doing a complete detailing of the car. Ultimately, this is a beneficial procedure to undertake, especially when using appropriate equipment and waxes.
Β
The suggestion of using a clay bar is excellent. I have previously applied a clay bar to the surface, but I did not specifically target the places. Therefore, I am considering using the clay bar on one of the locations to assess its effectiveness. Greetings
