HushedGamer Posted June 16 Share Posted June 16 I purchased Pagid brake pads, confirmed their compatibility, and both Halfords and Car 4 for Less said they were OK. Link to comment Share on other sites More sharing options...
HushedGamer Posted June 16 Author Share Posted June 16 https://www.halfords.com/motoring/car-parts/brakes/brake-pads/pagid-brake-pads-101221098-20258838000030.html?clickref=1011lBmL5PVg&utm_medium=affiliate&utm_source=skimlinks_phg&utm_campaign=phgreferral Link to comment Share on other sites More sharing options...
HushedGamer Posted June 16 Author Share Posted June 16 Nonetheless, the box indicates Audi Q8/Q7 and VW Touareg, as seen below. Can someone assist in confirming their compatibility with Indeed? Alternatively, if Halfords sent me with the incorrect item Link to comment Share on other sites More sharing options...
BrambleBurt Posted June 16 Share Posted June 16 Examine pagid.brakebook.com Link to comment Share on other sites More sharing options...
HushedGamer Posted June 16 Author Share Posted June 16 Thank you, that directs me to Euro Car Parts, which confirms their compatibility. I will examine the other barcode on the box in the morning and see whether it is “101221098.” Link to comment Share on other sites More sharing options...
BrambleBurt Posted June 16 Share Posted June 16 You may consider using Autodoc and doing a cross-reference with other brands. Link to comment Share on other sites More sharing options...
Lemmand Posted June 16 Share Posted June 16 Part # X pertains to Mercedes Benz. Extract the obsolete brake pads and conduct a comparison. Link to comment Share on other sites More sharing options...
TypoQueen Posted June 16 Share Posted June 16 It is likely not the only instance that day in which Halfrauds provided the incorrect portion due to unreliable guidance. Link to comment Share on other sites More sharing options...
CodeCabbie Posted June 16 Share Posted June 16 Numerous vehicles use same or similar callipers; hence, it is likely accurate. Link to comment Share on other sites More sharing options...
NightHawk47 Posted June 16 Share Posted June 16 A multitude of components is compatible with diverse models. I often see instances where Aston components priced at hundreds of pounds are identical to Ford parts that cost £15. Manufacturers do not produce these components; they design in accordance with market availability. Consider bulbs, O-rings, oil filters, and, of course, brake pads. At the age of 18, I purchased brake pads for my 3.0 litre Capri. The cost was £25. The pads were same for both the 2-liter and the 1.6-liter models. However, priced at £20 and £12, respectively. Identical pads, identical box, different number; they were also compatible with Granada and Cortina models. Another client, a self-employed mechanic, found amusement in my uninformed purchase. Link to comment Share on other sites More sharing options...
Spiderer Posted June 16 Share Posted June 16 Many smaller manufacturers excel at scavenging components from parts bins. Years ago, I had a buddy who had an ancient Maserati—though I cannot recall the specific model—that required a clutch replacement. The authentic piece from Masser was, undoubtedly, exorbitantly priced. However, after doing some investigation, he found that it was, in fact, the same unit that was installed in the Bedford CF van. Link to comment Share on other sites More sharing options...
