Brake servo for Mercedes 608D.
My 1986 Mercedes 608d vehicle necessitates the brake servo, part number A0014304630. Is assistance available? One or two are listed for sale online, although they are 'out of stock' when I try to buy them. Is it possible for me to locate a repair kit? I have conducted an exhaustive search and am currently at an impasse.
Companies such as Pastparts will not undertake the reconditioning of the unit unless I can procure a repair kit, which I am unable to do. Is anyone aware of alternative servos that may be compatible?
The mechanic used a little amount of loosening agent and manipulated the rod many times. This sensation is pleasant; the pressure appears adequate, as though the diaphragm is functioning properly. I will reattach this. The issue persists. At this juncture, it was seen that air was being inhaled through the breather tube. Recede the servo.
Upon exerting pressure on the brake pedal, it first exhibits significant resistance; but, with additional force, the pedal rapidly descends to the floor, resulting in an emergency stop of the car. Depending on the pedal's mood, it may gradually return to the top position and disengage the brakes; however, in most instances, the pedal must be manually lifted back up to release the brakes.
I have replaced the master cylinder and the wheel brake cylinders.
