Procedure for replacing a headlight bulb
Startle
Greetings, everyone.
One of the headlight bulbs on my 2014 Auris hybrid is no longer functioning.
I have recently conducted a search for an automobile component on the Euro automobile Parts website.
The price they are charging for a single bulb is £45 or more.Are they mocking or ridiculing? Is there a more affordable alternative or is that the prevailing price?
Greetings
It seems that the bulb in question may be a d1s bulb or a similar kind. Typically, I sell these bulbs for between £30 - £40 to provide a competitive price compared to Halfords. However, if you're fortunate, it might be a h7 bulb or a similar type, which are priced at under £5. I recommend visiting your local parts store, as they are often willing to offer better deals than larger companies.
The bulb is likely an HIR2, which stands for 'halogen infra red 2'. Alternatively referred to as a 9012.
Utilised in some models of Vauxhall Insignias and Amperas. Additionally, there are a few compact Toyotas available, such as the Yaris. It is rather uncommon. If I recall correctly, Halfords did not have these in store until around 5 years ago.
The ECP pricing seems to be on the higher side.
If you can endure the delay, I would recommend making the purchase online.
I would get a pair since they often malfunction in rapid succession, and the "brighter" ones (regardless of the brand) have a much shorter lifespan.
The initial equipment mostly consisted of Philips, with Toshiba being a secondary option. Philips manufactures many sorts of products with varying intensities. If your items are authentic, they will most likely be labelled as Philips LL. I understand this to imply an extended lifespan (with typical magnitude).
The Optibrite bulbs, manufactured by Philips, are supplied by Toyota dealers. However, it is worth noting that these bulbs have a stated life expectancy of just 500 hours.
It is likely that you have discovered that a single bulb is responsible for both high and low beams, achieved by a mechanism including a solenoid-driven mechanical shutter. Therefore, the malfunctioning of a single blown bulb has resulted in the failure of both beams in that headlamp. If both lights fail simultaneously (based on personal experience!), it may be rather unpleasant.
I have previously used the services of this organisation without encountering any issues. It may be advantageous to input your registration details and conduct a thorough examination.
I was unaware of the existence of such a bulb.
HIR2 bulbs have been in existence for around 15 years. They were first used as original equipment in vehicles such as the Toyota IQ (2009 onwards), second generation Auris, and Aygo.
Can be purchased on Amazon and other platforms in either the normal or enhanced versions.
I was inclined towards the brighter options due to the inadequate illumination provided by the lights on this particular model.
I am aware that the lifetime is quite short, which is somewhat disheartening. However, there is nothing that can be done about it.I have searched online at other websites, but they are not much less expensive. Additionally, I am concerned about the possibility of them being non-functional due to rough handling during shipping
Presently, the Philips X-tremeVision Pro150 bulbs are priced at around £25 per unit on Amazon.
Regarding the rough treatment during shipping, the bulbs are unlikely to have been treated delicately while transported from the manufacturer to the importer, distributor, retailer, or any other party involved. The same may be expected for bulbs provided by Euro Car Parts.
I decided to take a risk and purchased an inexpensive pair of HIR2 LED bulbs for £9. Given the price, the durability of the product remains uncertain, however it represents a significant improvement compared to the first candle light halogens (as seen in the accompanying picture). The items were sent in a well-protected box with a foam insert.
https://www.ebay.co.uk/itm/285235510906
The MOT underwent revision either in 2021 or 2022 to prohibit the use of LED or HID bulbs in headlamp assemblies specifically meant for halogen lights.
Some members claim that their cars have successfully passed MOTs with LED bulbs installed in halogen headlamp units. While this may be deemed acceptable, the problem lies with the individual tester rather than the test procedure itself. The possibility of the owner receiving a fine persists in future testing.
