HolyRoach Posted August 12, 2024 Share Posted August 12, 2024 How can I determine the dimensions of the brake discs on my 2008 CLC200? Unfortunately, I am unable to bend down in order to remove the wheel and measure it. Consequently, I am interested in purchasing a set of replacement brake discs. Link to comment Share on other sites More sharing options...
Angurita Posted August 12, 2024 Share Posted August 12, 2024 There is no need to detach the wheel. Instead, place a straight object across the top and bottom of the disc by inserting it between the wheel spokes. Then, measure the distance between these two points. Link to comment Share on other sites More sharing options...
Startle Posted August 12, 2024 Share Posted August 12, 2024 Requires fewer hands when measuring from the outside border to the middle of the hub and multiplying the result by two. Link to comment Share on other sites More sharing options...
Angurita Posted August 12, 2024 Share Posted August 12, 2024 Requires fewer hands when measuring from the outside border to the middle of the hub and multiplying the result by two. Link to comment Share on other sites More sharing options...
NameInterest Posted August 12, 2024 Share Posted August 12, 2024 Allow the individual who is responsible for fitting them to take the measurements. No manual dexterity required, nor any reliance on magnets or straight edges. 👍👍 I estimate the measurement to be 288 millimetres. Link to comment Share on other sites More sharing options...
HolyRoach Posted August 12, 2024 Author Share Posted August 12, 2024 Regrettably, I must purchase the items in order to have them properly installed. Therefore, I will need to explore other methods. However, my estimate for the front is likewise around 288. Bigger size is superior! Link to comment Share on other sites More sharing options...
NameInterest Posted August 12, 2024 Share Posted August 12, 2024 Verify the information on any website by inputting your registration number. 👍 Many firms compare the components against your registration number and dispatch the appropriate parts. Link to comment Share on other sites More sharing options...
AmericaMonster Posted August 12, 2024 Share Posted August 12, 2024 If you exceed the appropriate size, the calliper will not be able to fit. Link to comment Share on other sites More sharing options...
NameInterest Posted August 12, 2024 Share Posted August 12, 2024 Inform them, my friend. 👍 Link to comment Share on other sites More sharing options...
Boxck Posted August 12, 2024 Share Posted August 12, 2024 Retrieve the vehicle's Vehicle Identification Number (VIN) and request a quotation from Mercedes Newcastle or Edinburgh. Link to comment Share on other sites More sharing options...
Tactical Posted August 12, 2024 Share Posted August 12, 2024 However, sometimes they make errors. It is more advantageous to use an Electronic Parts Catalogue (EPC) and your Vehicle Identification Number (VIN) to get the authentic Mercedes-Benz component number. Next, go to the MB store and make the purchase. Alternatively, if you want to make a purchase from a different source, you may look for the MB component number on websites like AutoDoc, where you will find a range of aftermarket options. Then search for reputable brands like as ATE, Brembo, Zimmermann, and others that are recognised for their quality. Link to comment Share on other sites More sharing options...
Tactical Posted August 12, 2024 Share Posted August 12, 2024 Here is an Energy Performance Certificate (EPC): https://partsouq.com/en/catalog/genuine Link to comment Share on other sites More sharing options...
NameInterest Posted August 12, 2024 Share Posted August 12, 2024 Autodoc is really accurate, isn't it? I am laughing uncontrollably. 🤣🤣 Shirley, would it be more advantageous to travel to a nearby ecp shop rather than mailing the item back to Germany? Link to comment Share on other sites More sharing options...
Racerse Posted August 12, 2024 Share Posted August 12, 2024 When I changed my front discs, I had the choice between two different sizes, with little difference between them. Measuring the diameter precisely may be challenging when there is a hub obstructing the route. An alternative approach is to measure the circumference and then divide it by 3.142. I had sufficient confidence in the accuracy of the measurement to place an order with Autodoc, and the items I received were of the exact size. Link to comment Share on other sites More sharing options...
