Noxious emissions sound
Barringer
Greetings, everyone.
I own a 2013 Kia with a 1.6 CRDI engine and 4 tech features.
When operating at around 1600rpm, there is a narrow range of engine revolutions when I get a distinct noise like a rattling sound. (Excluding all the people, specifically referring to the automobile)
Based on my perception, there seems to be an exhaust blast occurring simultaneously with the turbo spooling up. However, I have some apprehension that this might be attributed to the turbo bearings vibrating.
It is quite frustrating since the roads in my area are mostly designed for driving, and this issue occurs when I reach a speed of around 58mph when in 6th gear. Consequently, it becomes a persistent source of irritation when I attempt to maintain a speed of 60mph on winding and steep roads. Most of the time, I find myself driving in 5th gear to maintain high engine revolutions and, as a result, I likely use a significant amount of diesel unnecessarily.
Has anybody else experienced this?
That seems logical. I was mostly concerned about the possibility of a defect in the turbocharger itself.
Now I need to determine whether it is worth investing on a thorough analysis and welding for a vehicle that is 11 years old and valued at £2000.
Inspect for any traces of black carbon residue.
The potential causes might be either the turbo gasket or the manifold gasket.
Even the exhaust gasket...
Enlist someone to impede or obstruct the tailpipe and see whether any auditory changes occur. Are you experiencing any symptoms related to gas leakage or a malfunctioning gas jet?
My device has also been experiencing intermittent malfunctions. I perceive the sound more prominently when you deactivate the engine when the door or window is open. I have identified the origin of the issue as the horizontal seam located on the middle silencer of the exhaust system. The surface has had little delamination and there is a minor leakage present. I am contemplating the use of exhaust putty to cover the affected area, since there are no visible signs of rust.
Please examine that location and see if you are experiencing a similar problem.
