baelicious Posted May 20, 2024 Share Posted May 20, 2024 I have never really contemplated purchasing a first-generation vehicle owing to concerns about the reliability of its gearbox, known as the R tonic gearbox. I had been considering purchasing a second-generation vehicle, but I just came across a 2014 V10 Plus with low mileage that caught my attention due to its appealing features. The one drawback I can see is that the warranty for this product is twice as costly as that of the second generation, amounting to £2000 a year compared to £1000. Is there anything else I am overlooking? Link to comment Share on other sites More sharing options...
HolyRoach Posted May 20, 2024 Share Posted May 20, 2024 The V10 Plus does not include the R-Tronic gearbox. The gearbox is a twin clutch S-Tronic. Link to comment Share on other sites More sharing options...
baelicious Posted May 20, 2024 Author Share Posted May 20, 2024 This factor is causing me to contemplate this option. I failed to clarify it in my first post. I became aware around one week ago. I believed that all of them were equipped with the r-tronic gearbox. Link to comment Share on other sites More sharing options...
Cassole Posted May 20, 2024 Share Posted May 20, 2024 The previous two iterations of the car (namely the updated version) were equipped with S-Tronic gearbox. Link to comment Share on other sites More sharing options...
Ziinsig Posted May 20, 2024 Share Posted May 20, 2024 It is important to note that although the 2014-2015 Gen 1 V10 vehicles are equipped with S-Tronic, they do not provide the same level of performance as the Gen 2 Plus models, even when comparing Gen 1 Plus to Gen 2 Plus. If performance is a priority for you, it is advisable to consider and compare both options by test driving them, since the Gen 2 model is much faster. However, I must express my admiration for the Gen 1 Plus model since it was a superb vehicle and visually more appealing than the Gen 2 (based on my own perspective). Link to comment Share on other sites More sharing options...
SlayNeo Posted May 20, 2024 Share Posted May 20, 2024 Both transmissions are S-tronic dual clutch, as Osman said. (However, it is worth noting that the Gen1 model is available with a manual gearbox, but the Gen 2 model does not provide this option.) However, if you choose to remain in automated mode, the two most significant distinctions will be: 1- Aesthetics (subjective) 2-Improved Performance (Gen 2 exhibits superior performance) Both engines are fundamentally same with minor differences. The main difference is that Gen2 incorporates both port and direct injection, whereas Gen1 is limited to direct injection alone. Gen2 is not expected to have carbon build-up problems on the valves, unlike Gen1. The Gen2 model has more power and may be readily adjusted to higher levels than the Gen1 model, if desired. Another significant factor to consider is variations in gearing. Furthermore, the interior technology is significantly distinct. Comparison between digital technology and first-generation analogue technology. The second generation of the R8, known as Gen2, is expected to have somewhat higher value in the near future due to its more recent release. However, if you are seeking enduring worth, it is probable that it will ultimately revert to Gen1. This is only my own viewpoint. In my subjective viewpoint, the latest Gen2 makeover exhibits a greater degree of distinctiveness and nostalgia towards Gen1. The Gen2 pre-FL has an extremely angular and rectangular shape. Link to comment Share on other sites More sharing options...
Racerse Posted May 20, 2024 Share Posted May 20, 2024 Ultimately, it boils down to identifying the appropriate specification. Aesthetics refers to the branch of philosophy that deals with the nature and appreciation of beauty, particularly in art and design. The performance is imperceptible to the buttocks. I was attracted to the modifications made to the gen2 body style, so I decided to make a buy. I am now observing the first generation models and my preference for them is increasing. Difficult decision Link to comment Share on other sites More sharing options...
SlayNeo Posted May 20, 2024 Share Posted May 20, 2024 I concur that the subjective perception of the buttocks does not discern any difference. Both may be either series/parallel (S/C) or transverse/transverse (TT). It is essentially the same engine. The distinction lies in aesthetics. And the technology you want inside, in my opinion. If you like analogue instruments, tiny displays, the traditional method of turning a key to start the vehicle, the option of a gated manual gearbox and a more subdued interior, then the Gen1 model would be the suitable choice for you. If you want the most up-to-date technological features from Audi, like a virtual cockpit with a bigger screen, a more sophisticated interior (including seats that are not sourced from an A4 like the first generation), push button start, drive choose, and an improved steering wheel, then the second generation would be the optimal choice. Link to comment Share on other sites More sharing options...
