HeadlinesQuick Posted January 15, 2024 Share Posted January 15, 2024 Greetings, everyone. Recently, my four-wheel drive vehicle was diagnosed with a fractured manifold after a decrease in engine output. The turbo is in good condition. Is it recommended to repair the timing chain while the engine is removed for manifold replacement? The 4x4 vehicle performs well without any concerns related to the timing chain. In October of last year, the oil cooler was changed and it was advised to also repair the intake motor (the specific name of which I cannot recall) simultaneously. Any advice would be highly appreciated. Link to comment Share on other sites More sharing options...
Carishme Posted January 15, 2024 Share Posted January 15, 2024 It depends on the mileage. Could you provide the mileage? Could you please provide information on the service history? Occasionally, it is most advisable to refrain from intervening if something is not malfunctioning. However, it is often advisable to do preventive maintenance while you are already at that location. The duration for which you want to retain the automobile also plays a role. Link to comment Share on other sites More sharing options...
HeadlinesQuick Posted January 15, 2024 Author Share Posted January 15, 2024 I have a mileage of 97,000. The vehicle has been serviced by both a dealer and an independent Mercedes expert. I anticipate retaining ownership of the automobile for around another 4 years. Link to comment Share on other sites More sharing options...
MutanX Posted January 15, 2024 Share Posted January 15, 2024 It would be prudent to replace the chain while you still have the opportunity. What is the average annual mileage you drive? Link to comment Share on other sites More sharing options...
HeadlinesQuick Posted January 15, 2024 Author Share Posted January 15, 2024 An average of 5,000 dollars every year for the last four years. Presently, the value stands at 7,000. Link to comment Share on other sites More sharing options...
MutanX Posted January 15, 2024 Share Posted January 15, 2024 If my financial situation permits, I would choose to replace it for peace of mind while the engine is removed. Having a Full Service History (FSH) would be a valuable asset when the opportunity arises for selling. Link to comment Share on other sites More sharing options...
Spiderer Posted January 15, 2024 Share Posted January 15, 2024 Is the engine being removed in order to replace a manifold?...and it is said that automobiles are improving!! Link to comment Share on other sites More sharing options...
Carishme Posted January 15, 2024 Share Posted January 15, 2024 New autos are deteriorating significantly. Link to comment Share on other sites More sharing options...
NotePapa Posted January 15, 2024 Share Posted January 15, 2024 I had the exhaust manifolds rebuilt on my Vito, which has the OM642 V6 engine. This required removing the engine and transmission. However, I wondered whether there might be easier access in a GL model. The manifolds possess a steel liner that may undergo delamination, resulting in the release of metal fragments into the turbocharger, necessitating the replacement of the turbocharger as well. Prior to this, I was unaware of any instances where manifolds have been reported to break, as described by the original poster (OP). Link to comment Share on other sites More sharing options...
Uneripty Posted January 15, 2024 Share Posted January 15, 2024 I would be astonished if it requires removing the whole engine. It is feasible to do the task on a Vito equipped with a 642 engine without the need to remove the engine. We have completed two tasks at this location. If the chain is making a rattling noise during a cold start, take the necessary steps to address the issue. Link to comment Share on other sites More sharing options...
HeadlinesQuick Posted January 15, 2024 Author Share Posted January 15, 2024 There is no sound of chains rattling. I have received a quotation of £700 from the dealers for a chain kit, and as a result, I have chosen not to proceed with the purchase. Although I lack extensive knowledge about the repair process, I contacted another Mercedes professional who confirmed that replacing the manifold on the GL would require removing the engine. Link to comment Share on other sites More sharing options...
