Adv3nture Posted April 29, 2024 Share Posted April 29, 2024 I had the oil changed at Audi and noticed that the back oil pan cover is now gone. After using Audi's services for a period of 6 years, I am aware that it did not suffer any damage or detachment. However, I now need a replacement. The price quoted for the Audi is $1300.00. I am uncertain about the duration of time since it was last turned off. The records of the mechanic who performed the repair were examined, and it was found that he had not made any prior statements. It does not resemble a bolt that falls onto the floor and becomes difficult to locate. Do you have any opinions or ideas? Link to comment Share on other sites More sharing options...
Talentrews Posted April 29, 2024 Share Posted April 29, 2024 I am unfamiliar with the term "oil pan cover" since I do not possess knowledge about an oil pan.There is an aerodynamic tray located over an aluminium engine heat shield. What is eluding my understanding? Link to comment Share on other sites More sharing options...
RacingNight Posted April 29, 2024 Share Posted April 29, 2024 I recommend searching on eBay for replacement components. There are other options available for purchasing the identical components at lower rates. Link to comment Share on other sites More sharing options...
Ledgerciao Posted April 29, 2024 Share Posted April 29, 2024 Do you have any specific component numbers? As previously mentioned, there is an absence of an oil pan. Link to comment Share on other sites More sharing options...
Adv3nture Posted April 29, 2024 Author Share Posted April 29, 2024 Is there a protective covering over the location where the oil drains? Link to comment Share on other sites More sharing options...
Talentrews Posted April 29, 2024 Share Posted April 29, 2024 The vehicle has a spacious alloy heat shield, which includes an access hole specifically designed for the drain plug. The drain plug is completely naked, without any "pan". Link to comment Share on other sites More sharing options...
Sumoto Posted April 29, 2024 Share Posted April 29, 2024 Below, there is consistently an opening for access. Link to comment Share on other sites More sharing options...
Talentrews Posted April 29, 2024 Share Posted April 29, 2024 Negative, the absence of such a thing is evident. In the case of newer autos, the recommended position is entirely closed. Link to comment Share on other sites More sharing options...
Ledgerciao Posted April 29, 2024 Share Posted April 29, 2024 Upon examining the gen2 from below, these are the details that I remember. Link to comment Share on other sites More sharing options...
Talentrews Posted April 29, 2024 Share Posted April 29, 2024 Engaging in the task of changing your own oil allows you a complete understanding and appreciation of the process. Approximately 70 bolts are required to remove both trays. Link to comment Share on other sites More sharing options...
Adv3nture Posted April 29, 2024 Author Share Posted April 29, 2024 I am uncertain about my objective. If someone comes across it on eBay or other websites, please inform me. I need assistance from all of you. Appreciation is extended to each and every one of you. Link to comment Share on other sites More sharing options...
