Uneripty Posted March 30, 2024 Share Posted March 30, 2024 I drove home, pulled into the driveway, and clicked the'start' button to stop the engine. Suddenly, everything turned off. I am unable to remove the key or turn on the engine. There are no clicks, and there is no life in the vehicle. Do you have any suggestions? Link to comment Share on other sites More sharing options...
Lemmand Posted March 30, 2024 Share Posted March 30, 2024 To begin, I would do a battery test by charging it for a few hours and observe any observable impact. Internal failure may occur abruptly, as I personally experienced. Link to comment Share on other sites More sharing options...
TraumaLaugh Posted March 30, 2024 Share Posted March 30, 2024 The recall for the large cable located at the rear of the fuse board, situated behind the glove box, has been initiated. It has a designation, although I am now unable to recall it. 07 is equipped with a keyhole that allows you to unlock the boot, allowing you to temporarily detach the battery. Link to comment Share on other sites More sharing options...
Uneripty Posted March 30, 2024 Author Share Posted March 30, 2024 Thank you both. The concept of batteries is logical, however I have never seen it in any automobile before. There were several instances of autos failing to start in the morning. I opened the boot with the keyhole this morning and then tested the fob to activate the central locking. Everything is now functioning normally. I have scheduled an appointment for a battery test later today. I have no recollection of cable. Link to comment Share on other sites More sharing options...
Squirrrel Posted March 30, 2024 Share Posted March 30, 2024 Conduct a thorough inspection of all battery connections, including the terminals to the chassis, front, and back. Link to comment Share on other sites More sharing options...
TraumaLaugh Posted March 30, 2024 Share Posted March 30, 2024 Yesterday, I was unable to recall the concept of B+ cable. I had a complete power outage, namely after parking and securing my vehicle and returning to a non-functional vehicle. After a period of time, it resurfaced. While several suggested removing the battery, I lacked a keyhole, which left me unable to proceed. One observation I made was that the period it did not need resetting was only delayed by around 15 minutes. If you failed to remove the battery, observe the time. Link to comment Share on other sites More sharing options...
Uneripty Posted March 30, 2024 Author Share Posted March 30, 2024 The battery level is now at 65%. If this occurs again, I will proceed with inspecting the wires as recommended. Thank you for your guidance and assistance. Link to comment Share on other sites More sharing options...
