Grundysp Posted March 21, 2024 Share Posted March 21, 2024 Greetings, I just purchased a 2012 C180 vehicle. One notable feature is that the SatNav volume is muted, indicated by a red cross on the speaker shown on the screen. I am unable to determine the method to unmute it. I have attempted to modify the volume, but have been unable. Any suggestions would be much appreciated. Link to comment Share on other sites More sharing options...
Ziinsig Posted March 21, 2024 Share Posted March 21, 2024 To mute and unmute, press and hold this button. However, it is quite bothersome since you must do so while the person is speaking. Link to comment Share on other sites More sharing options...
Darthilli Posted March 21, 2024 Share Posted March 21, 2024 As said before. The adjustment of volume is necessary during a SatNav message, especially when the speaker is engaged in conversation. To repeat the previous instruction, just push the button, and thereafter modify the volume upon hearing the SatNav message once again. Link to comment Share on other sites More sharing options...
Darthilli Posted March 21, 2024 Share Posted March 21, 2024 It should be noted that the 2012 vehicle will be equipped with either the Audio20 infotainment system, which is the entry-level model with the Becker Map Pilot navigation processor located in the glove box, or the COMAND NTG4.5 unit, which is the higher-end model including built-in navigation on the internal HDD. Are you aware of the specific one you possess? Link to comment Share on other sites More sharing options...
Grundysp Posted March 21, 2024 Author Share Posted March 21, 2024 Greetings, I am uncertain about the specific system that is already in place. I will examine it this morning. However, the books that were sent with the automobile are intended for the Audio 20 system. Link to comment Share on other sites More sharing options...
Grundysp Posted March 21, 2024 Author Share Posted March 21, 2024 I am unfamiliar with this button, but I will verify it later today. Thank you. Link to comment Share on other sites More sharing options...
Darthilli Posted March 21, 2024 Share Posted March 21, 2024 If that is the case, proceed to do an online search for an instructional handbook pertaining to the Becker Map Pilot for Mercedes. The Becker Map Pilot navigation processor is located in the glove compartment. It can be detached from the vehicle and connected to a PC via a Mini-USB connection (distinct from the smaller Micro-USB). Once connected, the firmware may be updated at no cost, while the maps can be updated for a fee. Link to comment Share on other sites More sharing options...
Grundysp Posted March 21, 2024 Author Share Posted March 21, 2024 Thank you. Link to comment Share on other sites More sharing options...
Grundysp Posted March 21, 2024 Author Share Posted March 21, 2024 I attempted to use the mute button, but regrettably, it would not function on my device, thereby rendering me unable to access any of the system menus. Link to comment Share on other sites More sharing options...
Ziinsig Posted March 21, 2024 Share Posted March 21, 2024 The act of unmuting may be achieved with a brief push, or alternatively, the volume level may have been adjusted to zero. There is a previous topic where the individual had to push the mute button and then press it again in order to activate it. Link to comment Share on other sites More sharing options...
Grundysp Posted March 21, 2024 Author Share Posted March 21, 2024 I have attempted to adjust the level while driving, anticipating instructions, and have also pressed and held the mute button. However, these attempts have been unsuccessful. I would really appreciate any suggestions you may have. Link to comment Share on other sites More sharing options...
Ziinsig Posted March 21, 2024 Share Posted March 21, 2024 Apologies for the failure. I assume you have already examined the handbook by now. Link to comment Share on other sites More sharing options...
Grundysp Posted March 21, 2024 Author Share Posted March 21, 2024 Indeed, my first search yielded no results. Link to comment Share on other sites More sharing options...
Ziinsig Posted March 21, 2024 Share Posted March 21, 2024 I own an antiquated command, however it seems that it operates in a distinct manner. Link to comment Share on other sites More sharing options...
Grundysp Posted March 21, 2024 Author Share Posted March 21, 2024 I have engaged in a conversation with an independent individual who was unable to provide guidance on the process. Consequently, I intend to attend a service in a few weeks if I am unable to resolve the issue. Link to comment Share on other sites More sharing options...
Darthilli Posted March 21, 2024 Share Posted March 21, 2024 The inclusion of a checkbox inside the Becker Map Pilot Settings menu is a possibility. Link to comment Share on other sites More sharing options...
