tr4s Posted February 29, 2024 Share Posted February 29, 2024 Hello everyone, I would appreciate any input from the group. Our 2009 W211e280 sport has just reached 100k miles and had been problem-free until yesterday. After driving 40 miles, I got home and noticed a minor clunk when I placed the vehicle in reverse. While reversing, it seemed like the brakes were sticking at low speed. Upon starting the engine, the vehicle experiences mild jolts and judders while moving at lower speeds. Additionally, there is a sensation of the engine surging slightly while in park. It operates smoothly when driving and changes through the gears adequately. Choosing the opposite option allows me to detect a binding noise. If it were a front-wheel-drive automobile, I would suspect that the drive shafts could be deteriorating, but obviously, this is not the case. The garage where we have it serviced is closed until Monday. I will attempt to use a code reader on it. Does it seem like the torque converter is failing? I would appreciate any guidance or tips. Cheers Link to comment Share on other sites More sharing options...
spartan Posted February 29, 2024 Share Posted February 29, 2024 A lifespan of 100,000 miles would be considered short for a TC, with twice that amount being more common, unless the lubricant is highly polluted. Link to comment Share on other sites More sharing options...
AmericaMonster Posted February 29, 2024 Share Posted February 29, 2024 What is the history of gearbox and filter ATF changes? Link to comment Share on other sites More sharing options...
tr4s Posted February 29, 2024 Author Share Posted February 29, 2024 I trust that "sealed for life" has not been completed yet. Link to comment Share on other sites More sharing options...
spartan Posted February 29, 2024 Share Posted February 29, 2024 Oh dear....... It is somewhat accurate, but if you don't replace it every 60 or 70 thousand miles, its lifespan might be significantly shortened. Link to comment Share on other sites More sharing options...
AmericaMonster Posted February 29, 2024 Share Posted February 29, 2024 Regrettably, it ended up being sealed till death. Service the box every 35,000 to 40,000 miles. £250-300 at an independent shop Link to comment Share on other sites More sharing options...
AmericaMonster Posted February 29, 2024 Share Posted February 29, 2024 The 2009 model, which is the same as mine, did not have a sealed gearbox for life. It had a gearbox service at 37500 km as a one-time occurrence. Link to comment Share on other sites More sharing options...
Meltarb Posted February 29, 2024 Share Posted February 29, 2024 I have received several recommendations about the ATF adjustment for my 2009 W211 E280 CDI Sports Estate. I purchased the automobile with 111,000 miles on the odometer. The previous history of ATF changes was ambiguous. Soon after buying it, I had the ATF replaced and a new filter installed. The current mileage is 190,000 miles. The use has been a combination of motorway and urban driving. I have completed all routine maintenance tasks myself... Aside from ATF and filter replacements. I just had another ATF and filter replacement performed by my reliable garage. Everything is fine. Functions just as well as the day I purchased it. Link to comment Share on other sites More sharing options...
Lovelyas Posted February 29, 2024 Share Posted February 29, 2024 It is not. Link to comment Share on other sites More sharing options...
Finestey Posted February 29, 2024 Share Posted February 29, 2024 Consider examining the ATF level and inspect for leaking at the pilot bush if it is low. ATF servicing is essential and should be done promptly. If the parking brake system is utilised, I would recommend having it inspected. Link to comment Share on other sites More sharing options...
Lovelyas Posted February 29, 2024 Share Posted February 29, 2024 Very same history as my E 320. Link to comment Share on other sites More sharing options...
tr4s Posted February 29, 2024 Author Share Posted February 29, 2024 Today, I took the automobile to the garage, and they thoroughly inspected it to identify the source of the vibration. The ATF was inspected and found to be clean and fresh, which is reassuring. The engine and gearbox mounts have been inspected and found to be in good condition. However, attention is now directed on the pulley at the front of the engine, which seems to be shaking and might be the cause of the issue. Hopefully. Link to comment Share on other sites More sharing options...
