KnightNewscast Posted February 21, 2024 Share Posted February 21, 2024 Hello everyone, Can someone confirm whether these particles in my oil are metal shavings? Thank you! Link to comment Share on other sites More sharing options...
BuffUpdate Posted February 21, 2024 Share Posted February 21, 2024 I am unable to see any images. Link to comment Share on other sites More sharing options...
Sumoto Posted February 21, 2024 Share Posted February 21, 2024 It might be a gasket seal, often including copper or silver flakes. If so, it may indicate head gasket issues from previous owners. Merely an estimate. Link to comment Share on other sites More sharing options...
BuffUpdate Posted February 21, 2024 Share Posted February 21, 2024 I have deleted all my data and cookies, yet the issue persists. Time to memorise the password now. Link to comment Share on other sites More sharing options...
Sumoto Posted February 21, 2024 Share Posted February 21, 2024 I dislike doing it, but all my passwords are stored on my Chromebook. Link to comment Share on other sites More sharing options...
KnightNewscast Posted February 21, 2024 Author Share Posted February 21, 2024 Could you kindly attempt to access this WeTransfer link: https://wetransfer.com/downloads/580d0445d66bf4ee9692c9a6da3bde3b20240221072504/c1bd63 Link to comment Share on other sites More sharing options...
Sumoto Posted February 21, 2024 Share Posted February 21, 2024 My intuition seems accurate. Some gasket seals, such as K seal, utilise copper while others use stainless steel. It is difficult to discern whether the substance in question is metal shavings, dust, or overspray. If it were indeed metal shavings, they would not be visible. The liquid in the image appears more like water than oil. If it is oil, then the level is excessively high. Could you provide more context about the image? Where is the oil cap located? Link to comment Share on other sites More sharing options...
KnightNewscast Posted February 21, 2024 Author Share Posted February 21, 2024 Hello Sumoto, I appreciate your timely answers, friend. I lack expertise on automotive matters. Approximately two years ago, I had an oil leak, and this image was one of the ones my technician shared with me. Currently experiencing an unusual problem where my 4 series is loosing oil pressure specifically at highway speeds. Most postings on this topic report low oil pressure at idle or while braking, with pressure increasing as RPMs grow. In contrast, my issue is the reverse. I suspect I may have harmed my engine since the oil pressure indicator has illuminated twice while I was driving at 70mph, leading me to overanalyze and inquire about metal shavings. I just had her undergo a comprehensive service, including a flush and oil change. However, the pressure lamp illuminated for the second time on my trip back home yesterday night. Exasperated! Link to comment Share on other sites More sharing options...
KnightNewscast Posted February 21, 2024 Author Share Posted February 21, 2024 Thank you once again😇 Link to comment Share on other sites More sharing options...
