DownContent Posted October 19 Share Posted October 19 Hi there, Our 2019 W177 A200's air conditioner is malfunctioning at the moment. The air conditioner won't turn on. The problem persists despite a local garage having re-gassed it and checked for leaks. There is a problem with the refrigerant level being too low, according to the OBD tool. It was recently re-gassed after being checked for leaks, so I know it isn't low on gas. There is no reading of 0 for the air conditioning system pressure in the onboard diagnostic monitor. In order to avoid leaking refrigerant, I was hoping to replace the pressure sensor and was wondering if there was a Schrader valve located behind it. Much obliged. Link to comment Share on other sites More sharing options...
AmericaMonster Posted October 19 Share Posted October 19 I experienced the problem at ATS a few years ago. No leaks detected during the nitrogen test. Damned if it weren't cool. Honestly, I don't know if there were any faults, but after I plugged in the reset codes on my iCarsoft, it started fixing the problem. Possibly a coincidence. Link to comment Share on other sites More sharing options...
DownContent Posted October 19 Author Share Posted October 19 After it was re-gassed and still wasn't working, I was hoping this was the problem, but when I checked, the code was still active and wouldn't clear. The reading is still showing 0, so I'm making an assumption. Link to comment Share on other sites More sharing options...
AmericaMonster Posted October 19 Share Posted October 19 How about a pressure switch? If you put a digital multimeter across the terminals, I have no idea what the resistance reading will be. The catch is that degassing is required to rectify that. Link to comment Share on other sites More sharing options...
Shmoein Posted October 19 Share Posted October 19 I just had a new pressure sensor installed on my A205 C200 today. Based on my research, it appears that the air conditioning issues on C Class (and other Merc) are caused by a faulty sensor. I replaced the old one with a new one, and now it's lovely and cold. Link to comment Share on other sites More sharing options...
DownContent Posted October 19 Author Share Posted October 19 It seems like the pressure sensor might be malfunctioning. One is on its way to me; I just placed the order. I'm crossing my fingers that it has a Schrader valve underneath so that the refrigerant can be safely replaced. Link to comment Share on other sites More sharing options...
DownContent Posted October 19 Author Share Posted October 19 It is my sincere wish that ours is likewise a sensor problem. That it re-energised yours is encouraging to hear. Link to comment Share on other sites More sharing options...
Talentrews Posted October 19 Share Posted October 19 Use caution. Unfortunately, one of our members just learned the hard way that not all Mercedes models are compatible with Schrader valves installed under the sensor. The sensor went flying out, followed by all the gas, and he felt a jolt as his fingers froze. Link to comment Share on other sites More sharing options...
RosaStyle Posted October 19 Share Posted October 19 Hello there!!!!! As far as I'm informed, every Mercedes is built without a Schrader valve. I serve as an example Link to comment Share on other sites More sharing options...
