TraumaLaugh Posted 29 minutes ago Share Posted 29 minutes ago The engine in my 2017 Mini Cooper S is essentially finished. I was operating a vehicle on the Interstate on Friday during daylight hours. Increased speed moderately and promptly experienced a decline in power, followed by alerts on the iDrive indicating diminished power and a drivetrain malfunction. Numerous misfire codes are present as well. I managed to drive the car home despite its limitations, covering a distance of approximately 5 miles. It probably caused additional harm, but I believe the primary damage occurred when the vehicle lost power. I commenced an investigation into the underlying cause and discovered this discussion: https://www.babybmw.net/threads/b48...threads/b48-b58-injector-failure-cracked-piston-bore-scoring-megathread.148577/ My vehicle aligns impeccably with the specified description. My vehicle is still equipped with the original injectors from before August 2017, which are responsible for the issue. I anticipated that the issue was merely injector malfunction, so I replaced them with the updated components, yet there was no improvement. Additionally, new spark plugs and ignition coils are included. Once more, there is no alteration. Subsequently, I conducted a compression assessment on all four cylinders. Cylinder 1 - 210 pounds per square inch. Cylinder 2 - 160 pounds per square inch. Cylinder 3 - 0 pounds per square inch. Cylinder 4 exhibits a pressure of 210 psi. It is probable that cylinder 3 possesses a fractured piston. Cylinder 2 is experiencing a problem with reduced compression. A fractured piston may also be present, along with potential cylinder scoring due to fuel washdown. I have thoroughly appreciated the vehicle and intend to repair it. The vehicle is clearly no longer covered by warranty, thus I will be undertaking the engine replacement independently. I intend to purchase a pre-owned engine and subsequently replace the existing one. Revitalize certain components. I have been utilizing a 93 octane Stage 1 Bootmod3 calibration. I cannot assert that this did not play a role in my engine deterioration, yet all the literature I have encountered regarding the B46/B48 engines indicates they are exceptionally robust and dependable. The 93 octane BM3 calibration is secure. I have additionally been utilizing a high-flow catalytic downpipe and an enhanced intercooler. It's unfortunate, but it is what it is. Link to comment Share on other sites More sharing options...
DaisyDrift Posted 28 minutes ago Share Posted 28 minutes ago Identical narrative to my 2017 Countryman Cooper S All4 that ceased functioning last week. Zero compression observed on cylinder two… I was also operating BM3 stage 1, but with 91 octane. I also have significant reservations that the melody was the cause of its demise. I discovered a service bulletin regarding the B48, indicating that the spark plugs must be oriented properly; otherwise, the electrode may disrupt the injector spray pattern and flame front, potentially leading to melted pistons and cylinder walls. Mercedes encountered the identical problem. Interestingly, I replaced the spark plugs with Bosch ones approximately six months ago… I still need to verify whether the plugs have different threading, but Bosch claims they are not clock-specific. I have been considering replacing the B48A20T1 from the LCI JCW models, but it appears to be a complex task due to the altered DME module and its utilization of a more recent "bordnetz" communication protocol compared to the 2017 BDC. Additionally, it necessitated replacing the transmission, although that would have been feasible. Link to comment Share on other sites More sharing options...
TraumaLaugh Posted 28 minutes ago Author Share Posted 28 minutes ago That is unfortunate. I have studied the technique of clocking spark plugs to achieve a marginal enhancement in power. However, I have never encountered GDI engines exhibiting such sensitivity. I question whether that was relevant to the situation. I would wager that your engine experienced the same problem as mine, given that it is also a 2017 model. My vehicle was equipped with the original injectors, and BMW developed an updated version. The injectors are prone to leakage, which erodes the oil from the cylinder walls, ultimately leading to piston failure. The discussion on the BabyBMW forum indicates that both the B46/B48 and B58 have encountered this issue. Examine the door label on the driver's side to ascertain the manufacturing date of your vehicle. If it predates August 2017 and contains the original injectors, that is the cause. My vehicle was manufactured in May 2017 and still possesses the original fuel injectors. I will procure a pre-owned engine and compile a list of components. I will simply replace it with the identical engine. I discovered several videos on YouTube featuring an individual who performed a swap on a 2017 Mini. This will assist in understanding the process, although I possess a basic comprehension of the necessary actions. My vehicle features a manual transmission, and there exists an ACT clutch installation video demonstrating the procedure for detaching the transmission from the automobile. I will execute that initially, followed by extracting the engine from above. Remove the obsolete components from the new engine and transfer the functional parts from my damaged engine to the donor. I contemplated performing the ACT clutch while I am present, but I remain uncertain. My factory clutch appeared to be functioning adequately with the 93 BM3 calibration. I am likely to acquire the entirely metallic oil filter housing/cooler since the standard plastic component is a recognized point of failure. Could you share the link to the spark plug clocking bulletin if you possess it? More inquisitive about it than anything else. I appreciate it. Link to comment Share on other sites More sharing options...
DaisyDrift Posted 27 minutes ago Share Posted 27 minutes ago My vehicle's date is March 2017, so I suspect the injectors are original 👎 I doubt they have been replaced, although it's possible - I will verify the part numbers on the injectors when I remove the engine. Legit streetcars recently released a video detailing a Mercedes engine failure caused by improper spark plug alignment, resulting in a melted cylinder wall - it seems almost unbelievable 🤯 The notice I possess is in Danish, but I will endeavor to translate it and forward it. Link to comment Share on other sites More sharing options...
TraumaLaugh Posted 27 minutes ago Author Share Posted 27 minutes ago Indeed, it is highly probable that you are experiencing issues with the injectors. What is the mileage on your vehicle? My vehicle has precisely 80,000 miles. And was functioning exceptionally well. I experienced an unusual drive train failure merely a month or two following my acquisition of the vehicle. I dismissed it at the moment, and a swift shutdown and reboot resolved the issue, which never recurred. However, I believe I remember an individual stating in a forum discussion that this could signify faulty injectors. The damaged engine serves as a clear indication of the issue.:( I possess knowledge of Legit Street Cars. It would be absurd if the timing of spark plugs led to engine failure. Manufacturers are driving engines to their limits to extract every micrometer of efficiency, primarily to comply with emissions standards. Link to comment Share on other sites More sharing options...
DaisyDrift Posted 26 minutes ago Share Posted 26 minutes ago My vehicle has reached 75,000 miles, thus it is comparable. I have experienced minor stuttering at partial throttle and occasionally a wisp of blue smoke upon ignition (I had the startup roar activated in bm3). I experienced minor pressure while opening the oil filler cap during operation, leading me to suspect the PCV valve; I had purchased a new valve cover but had not yet found the time to replace it… Currently, there is an excessive amount of compression in the crankcase; it resembles the sensation of placing your hand over the exhaust. Link to comment Share on other sites More sharing options...
