Impaired ML350 Bluetec EGR, DPF, and Adblue
MuffinClaw
Salutations, comrades,
I am a newbie here, and my 2014 ML350 Bluetec has been giving me nothing but trouble. 'Soot content in the diesel particulare filter is improbable,' error code 111500, first appeared in December and was reportedly triggered by the differential pressure and exhaust back pressure sensors. This was the beginning of the problems. Both sensors were swapped out without success. I replaced the DPF since it was not renewing and the fuel consumption was quite high (23 litres per hundred). All issues up to this point have been resolved; fuel usage is now stable, and the CEL is no longer an issue.
A few 300 km afterwards, an additional CEL appeared, and not long after that, the infamous Adblue Remaining Starts 10 notification. You may skip the "500 km remaining" and "16 starts remaining" Adblue messages and go right to the 10 starts. I filled up the Adblue since I felt it was low, but it didn't fix the CEL. And to top it all off, the exhaust began to strongly smoke a grayish-white colour, and the automobile had an odour that was completely foreign to me—neither diesel fuel nor ammonia, as far as I could tell. Everything calmed for another 200km when the fault codes (16CE00, 16CF00) were cleared, until CEL sprang up again.
Official dealer recommended updating the ECU software since Adblue wasn't talking to it correctly. That fixed the Adblue-related codes, but now I'm getting 14CF00, which means "The positive control deviation during exhaust gas recirculation control is too high," and 178200, which means "Efficiency of SCR catalytic converter." Since the DPF problems began in December, the 14CF00 code has intermittently prompted the CEL; the dealer says I must now clean the EGR valve, pipes, etc. This is great with me, and I will have it done. My biggest concern is pinpointing the source of the smoke; is it related to the EGR problem, the Adblue problem, or the just installed DPF? Both possibilities are being considered because the smoke didn't begin until after the Adblue tank was filled, and it was also soon after the DPF was replaced. The smoke appears out of nowhere on both highways and city streets, lingers for two to five minutes, and then disappears. The dealer claims, "It's just DPF regeneration," but I don't buy it because the DPF is brand new and I've never had problems like this before the Adblue problems began.
If you have any advice, please let me know.
Oh, I see. Buying my 1983 W123 200 is the way to go. I will not be using any electronics, adblu, DPF, warning lights, wind-up windows, LEZ fees, road tax, or MOT (though I'm sure someone on this forum will renew mine tomorrow), and my insurance is £89 a year.
But the problem is that I have to sell it since the sitting position is too much for my old knees.
The windows, steering, lighting, and gear shift are all powered by electricity. My arm, which is gripping the window winder, moves around and around in response to an electrical signal from my brain whenever I wish the windows open. As if by some enchantment, the window descends. Similarly, when I wish to park in reverse, my brain communicates with my arms. With one hand, I shift into backward while the other controls the wheel, and I park the car. My brain alerts my right arm, which then extends forward and flips the switch to the "on" position for the headlights whenever I detect that it has become dark outside. When I wish to shift gears, my brain signals my left arm, which in turn moves the gear stick. First, I'm smart, and second, I passed the driving test, so I can do all these amazing things. These high-tech vehicles equipped with computers are perfect for those who lack intelligence and have not yet completed their driver's license exam. The mechanics at the garage, alas, lack brains. Instead of utilising their limited cognitive abilities to accurately identify the issue, they blindly follow the instructions on their computer. So, the client ends up paying a hefty sum for unnecessary services.
