CrawlerTagz Posted February 27 Share Posted February 27 Greetings everyone; An updated cx90 for 2026 That was just this week that I made the purchase. I would prefer to be able to attach a battery tender to it because there may be instances when it is not driven. Slightly concealed beneath in the engine compartment on the passenger side is the 12-volt battery. Is accessing the battery itself the only hassle when connecting a battery tender? The fact that the battery is so out of sight is not an issue for me with other vehicles. Much obliged. Link to comment Share on other sites More sharing options...
RosaStyle Posted February 27 Share Posted February 27 You can reach the positive terminal of the battery with relative ease. A body ground wire is fastened to the fender immediately in front of the battery, while the negative terminal is concealed beneath the windscreen cowl. This is the location that the owner's manual suggests for jump starting, and it should work perfectly for a charger or tender. Link to comment Share on other sites More sharing options...
CrawlerTagz Posted February 27 Author Share Posted February 27 Thank you, RosaStyle. The delicate connection was a breeze thanks to you. So far, so good. Link to comment Share on other sites More sharing options...
Syncephe Posted February 27 Share Posted February 27 An eyelet connector that works with your battery tender could be used. It connects directly to the battery terminals and lets you move the connecting side to a better spot. Link to comment Share on other sites More sharing options...
CrawlerTagz Posted February 27 Author Share Posted February 27 Following your advice, I will attach a cord. Future hookups would be a breeze with that. Link to comment Share on other sites More sharing options...
