Kiddokt Posted 3 hours ago Share Posted 3 hours ago Historically, washers have been covered under warranty; however, we have been informed today that this is no longer applicable, and the cost to repair one that is blocked and nonfunctional is £175. This appears excessively costly. Has anyone else encountered a comparable experience? Link to comment Share on other sites More sharing options...
Istairde Posted 3 hours ago Share Posted 3 hours ago I recently updated mine on a Sorento; it was easy to remove without disassembling the scuttle, and pairs are available on Amazon for as low as £5. Link to comment Share on other sites More sharing options...
baelicious Posted 3 hours ago Share Posted 3 hours ago If they continue to be obstructed. Subsequently, it is essential to examine the underlying reasons. I have not experienced a single block in over ten years of owning a Kia. The primary cause of obstruction is the frequent interchange of washer fluid brands, as certain combinations do not blend effectively and result in sludge formation. Link to comment Share on other sites More sharing options...
NotePapa Posted 3 hours ago Share Posted 3 hours ago I would insert a hose into the washer reservoir to flush it thoroughly and refill it with a quality additive, consistently using the same product. Residue can be removed from the jets using a mixture of hot water and vinegar. While the jets are detached, I would also circulate clean water through the pipes to guarantee that the nozzles are also clean. Link to comment Share on other sites More sharing options...
Grundysp Posted 3 hours ago Share Posted 3 hours ago It is quite costly, and I would surely like not to replace it a second time. I would like to ascertain the prices charged by other mainstream brand dealerships for the same service in 2026, regarding the claim of being 'very costly.' Link to comment Share on other sites More sharing options...
NotePapa Posted 3 hours ago Share Posted 3 hours ago Technicians can complete the task in minutes, and components were not costly during my tenure at Kia; however, I would recommend cleaning them initially, as various washer fluids may coagulate when combined. Link to comment Share on other sites More sharing options...
Mezuzzi Posted 3 hours ago Share Posted 3 hours ago I also advocate for the consistent use of the same washer fluid. I replenish the bottle prior to a service to avoid contamination from an alternative mixture. The dealer leaves a little concentration bottle in the vehicle following the service. Link to comment Share on other sites More sharing options...
Cassole Posted 3 hours ago Share Posted 3 hours ago I consistently purchase the ready-to-use solution. I previously utilised the mix-with-water variant in my wife's vehicle and stored some in a litre bottle, only to discover the formation of a black sludge, likely due to the tap water employed for mixing. Consequently, I now employ the ready-mix solution in both vehicles. Link to comment Share on other sites More sharing options...
