MrTinkerFix Posted January 9 Share Posted January 9 Do you have any innovative suggestions for effectively putting a 52mm oil pressure or oil temperature gauge in the W204 facelift model? I seek a gauge that is seamlessly integrated, preferring a mount that is both practical and harmonises with the dashboard. It is likely that someone has accomplished it. Thank you in advance Link to comment Share on other sites More sharing options...
Lemmand Posted January 9 Share Posted January 9 Perhaps not... Link to comment Share on other sites More sharing options...
MrTinkerFix Posted January 9 Author Share Posted January 9 I seek something more nuanced than that. If there were an A-post mount that adequately fits a RHD W204, I would consider it. Link to comment Share on other sites More sharing options...
DaisyDrift Posted January 9 Share Posted January 9 Is your radio a double DIN or single DIN? If it is single DIN and there is a cubby hole beneath it, you may be able to acquire a blank panel to install gauges. Alternatively, if there is an unused ashtray, that could serve as a potential area for them. Link to comment Share on other sites More sharing options...
WordSnoop Posted January 9 Share Posted January 9 If you are prepared to forfeit one of the dash vents, you might install a gauge in that location. Link to comment Share on other sites More sharing options...
WordSnoop Posted January 9 Share Posted January 9 Link to comment Share on other sites More sharing options...
