12-volt battery
VodScanner
Hello, I need to install a tracker on my recently acquired 2022 CHR using the 12V battery connections.
Can I simply disconnect the connections and proceed as with a conventional vehicle, or must I exercise caution and adhere to a certain procedure?
Thank you in advance.
Numerous forum members appear to have exchanged batteries without encountering issues or without specific procedures. Note that the 12v battery possesses a minimal capacity, and if your tracker draws current while the vehicle is off, the battery will likely deplete.
