BuffUpdate Posted November 25 Share Posted November 25 Dear All, I possess a 2010 BMW 520D F10. I assessed the DPF status using an OBD2 reader and obtained the subsequent data regarding DPF regeneration. DPF - Distance Travelled Since Last Regeneration = 16,507 km (~10,257 miles) DPF Engine Operating Time Since Last Regeneration = 3010 hours, 5 minutes, 20 seconds DPF-Exhaust Gas Differential Pressure = 95.99 DPF-Soot Mass = 45.99 DPF-Status, Total Remaining Distance = 83,440 km I do not have any notice regarding the DPF on the dashboard. Could you assist me in comprehending the aforementioned readings? I travelled 60 miles last night at an average speed of 65 mph and have undoubtedly covered hundreds of miles in a single journey over the last 10,000 kilometres. What caused the DPF regeneration to fail? Thank you. Link to comment Share on other sites More sharing options...
Kenjibb Posted November 25 Share Posted November 25 The prerequisites for regeneration have not been satisfied for some reason. Link to comment Share on other sites More sharing options...
Darthilli Posted November 25 Share Posted November 25 The passive regeneration must be functioning effectively; otherwise, the DPF will be completely obstructed after 10,000 miles. Link to comment Share on other sites More sharing options...
BuffUpdate Posted November 25 Author Share Posted November 25 Thank you. Is it accurate to presume that DPF regeneration occurs only once a specific threshold of soot mass is attained, such as around 50 grammes? Should it occur every time you drive on the motorway for around an hour? Link to comment Share on other sites More sharing options...
Markwe Posted November 25 Share Posted November 25 Only upon reaching a specific threshold. Link to comment Share on other sites More sharing options...
Strongspoi Posted November 25 Share Posted November 25 Does it definitely have a diesel particulate filter? Link to comment Share on other sites More sharing options...
