MrTinkerFix Posted October 29, 2025 Share Posted October 29, 2025 I possess a 1995 E36 with a manual 5-speed transmission, and I am experiencing a noise when depressing the clutch pedal. What is the method to resolve this issue? Is it merely a bearing replacement? Link to comment Share on other sites More sharing options...
TypoQueen Posted October 29, 2025 Share Posted October 29, 2025 I would examine the number 4 bushings or the springs. Link to comment Share on other sites More sharing options...
TypoQueen Posted October 29, 2025 Share Posted October 29, 2025 Link to comment Share on other sites More sharing options...
MrTinkerFix Posted October 29, 2025 Author Share Posted October 29, 2025 However, the noise originates in the gearbox, caused by friction during rotation. Link to comment Share on other sites More sharing options...
TypoQueen Posted October 29, 2025 Share Posted October 29, 2025 The issue may likely be the thrust bearing, which can become loud yet function effectively for many years. Link to comment Share on other sites More sharing options...
MrTinkerFix Posted October 29, 2025 Author Share Posted October 29, 2025 Are you aware of the part number? I will attempt to rectify it. Link to comment Share on other sites More sharing options...
TypoQueen Posted October 29, 2025 Share Posted October 29, 2025 https://www.realoem.com/bmw/enUS/partxref?id=CB33-USA-06-1995-E36-BMW-325i&mg=21&sg=05&diagId=21_0292&q=21517521471&series=E36 Link to comment Share on other sites More sharing options...
PeakyOtter Posted October 29, 2025 Share Posted October 29, 2025 It would be prudent to install a new clutch concurrently, as it entails the same level of effort. Link to comment Share on other sites More sharing options...
GravyRocket Posted October 29, 2025 Share Posted October 29, 2025 The release bearing is damaged. The subsequent procedure involves seizing and perforating the clutch cover. You must remove the gearbox and replace the clutch. Relatively simple to manage them, even when positioned on axle stands. A new clutch costs approximately £120 for a four-cylinder non-air conditioning model (solid flywheel) and somewhat more for a 328i variant. Adhere to reputable brands such as LuK or Sachs. Typically, the 316i/318i/318is models from that year equipped with air conditioning use a twin mass flywheel. Link to comment Share on other sites More sharing options...
