JetstreamJay Posted 3 hours ago Share Posted 3 hours ago I have shared this in the "What have you done to your Merc today" thread, but I believe it may also be beneficial to put it here. I will provide any updates or solutions in due time. E350 CDi has the updated OM642 engine. EML activated en route to work on Friday. Successfully transported me there and back home, fortunately, without any apparent symptoms. Operated regularly, smoothly, without any knocks, responded well under moderate load, and emitted no smoke (did not attempt full acceleration). I presented it to my independent entity first thing this morning. It began adequately but exhibited hesitance in shifting gears. The vehicle shifts down automatically at approximately 3,000 RPM, while manual paddle shifting occurs at 2,500 RPM, and it does not exceed 5th gear with the 7G-Tronic gearbox. Otherwise, it seems satisfactory. I suspected the NOx sensor, but the mechanic disagreed, considering the gearbox issues observed this morning. I anticipate a call. Link to comment Share on other sites More sharing options...
BeardAndBeans Posted 3 hours ago Share Posted 3 hours ago The gearbox frequently enters a protective mode, as you said, when an engine failure occurs. Best of luck with the resolution. π Link to comment Share on other sites More sharing options...
JetstreamJay Posted 3 hours ago Author Share Posted 3 hours ago An electric motor has malfunctioned. I could not comprehend the statement, but I believe it pertains to the exhaust manifold. It is possible that the swirl flaps are malfunctioning. The turbo must be removed. The repair will not be inexpensive. Link to comment Share on other sites More sharing options...
MrTinkerFix Posted 3 hours ago Share Posted 3 hours ago Invest approximately 10 pence in a 4700-ohm resistor for the connector associated with the motor; bridge the central two pins; issue resolved. The vehicle will operate similarly, and there are no warning lights illuminated on the dashboard. Examine fuse number 24 as well. Link to comment Share on other sites More sharing options...
Lemmand Posted 3 hours ago Share Posted 3 hours ago Inlet port motor for swirl flap Link to comment Share on other sites More sharing options...
WordSnoop Posted 3 hours ago Share Posted 3 hours ago Alarm What is the car's mileage, and have the oil cooler seals been replaced? Completing the SF motor would render it imprudent not to replace the seals, as it requires but a few bolts and an additional 20 minutes of effort beyond the initial 10. Link to comment Share on other sites More sharing options...
SilentSpanner Posted 3 hours ago Share Posted 3 hours ago Why must the turbocharger (hot side) be removed if the issue pertains to the swirl flaps (cold side)? Link to comment Share on other sites More sharing options...
SilentSpanner Posted 3 hours ago Share Posted 3 hours ago π«’ Link to comment Share on other sites More sharing options...
