PeakyOtter Posted June 30, 2025 Share Posted June 30, 2025 I applied tire shine to my black window pillars, anticipating a polished appearance; nevertheless, exposure to sunlight resulted in a severe white stain. Despite my efforts to remove and clean it, the stain persists. Do you have any recommendations? Link to comment Share on other sites More sharing options...
RumbleRex Posted June 30, 2025 Share Posted June 30, 2025 Indeed, they are composite panels, not ABS plastic. May be compromised. Link to comment Share on other sites More sharing options...
SundayShoes Posted June 30, 2025 Share Posted June 30, 2025 Abundant rubbing alcohol and supplications. Link to comment Share on other sites More sharing options...
FrostyTomato Posted June 30, 2025 Share Posted June 30, 2025 Greetings, everyone! What is your opinion on Chemical Guys Blazing Banana Spray Wax? I cleaned my pillars with a cloth saturated with the solution. The results are satisfactory; nonetheless, I am hesitant to use it directly via spray.I believe it is a viable solution for the sun-damaged pillars; it may restore their luster. Best of luck. You might always consider having them refinished, I would assume. Link to comment Share on other sites More sharing options...
SundayShoes Posted June 30, 2025 Share Posted June 30, 2025 The pillars lack gloss, hence using any product labeled "shine" is likely to result in complications. Link to comment Share on other sites More sharing options...
