Tire gloss on window support
PeakyOtter
I applied tire shine to my black window pillars, anticipating a polished appearance; nevertheless, exposure to sunlight resulted in a severe white stain. Despite my efforts to remove and clean it, the stain persists. Do you have any recommendations?
Greetings, everyone! What is your opinion on Chemical Guys Blazing Banana Spray Wax? I cleaned my pillars with a cloth saturated with the solution. The results are satisfactory; nonetheless, I am hesitant to use it directly via spray.I believe it is a viable solution for the sun-damaged pillars; it may restore their luster. Best of luck. You might always consider having them refinished, I would assume.
