CrownChikk Posted May 22, 2025 Share Posted May 22, 2025 Hello, I have observed individuals claiming that BimmerLink possesses a misfire detection feature; yet, I am unable to locate it. Is this functionality exclusive to specific models? Alternatively, a guide to locate it. Thank you Link to comment Share on other sites More sharing options...
MamaKiddo Posted May 22, 2025 Share Posted May 22, 2025 Certainly, if a misfire occurs, the corresponding code would be recorded and then identified, similar to any other code, and shown during the faulty memory scan. I have never encountered a particular misfire function. Link to comment Share on other sites More sharing options...
CrownChikk Posted May 22, 2025 Author Share Posted May 22, 2025 I am experiencing an identical issue to previous post, and they are utilising it. They also indicate that they are not receiving a cell. Experiencing rough, juddering acceleration when cold, especially in recent warm weather, raising uncertainty regarding the glow plug or similar components. Link to comment Share on other sites More sharing options...
MamaKiddo Posted May 22, 2025 Share Posted May 22, 2025 This is a screenshot of the dashboard, and you may incorporate any desired sensors into it. I presume they have perused the list and incorporated it. If that specific sensor does not appear while scrolling, it is certainly unavailable to you; nonetheless, I had always assumed it would display all options and indicate "no data" for those not applicable. It is not a function; it merely displays sensor data. Link to comment Share on other sites More sharing options...
Talentrews Posted May 22, 2025 Share Posted May 22, 2025 As already said. The list is extensive, but the information will be included. I was searching for something the other day, and it took me a considerable amount of time; dyslexia does not assist me, unfortunately. Link to comment Share on other sites More sharing options...
CrownChikk Posted May 22, 2025 Author Share Posted May 22, 2025 It was not my screenshot; it was merely an example of another individual's. I am still unable to locate it. I will review it again later. My AuDHD is not beneficial to me either. 👍 Thank you for your responses. Link to comment Share on other sites More sharing options...
CrownChikk Posted May 22, 2025 Author Share Posted May 22, 2025 Link to comment Share on other sites More sharing options...
Talentrews Posted May 22, 2025 Share Posted May 22, 2025 I have reviewed my list, and it is not present. Is your car a diesel, similar to mine? The screenshot may have originated from the application utilised on a fuel, albeit I am uncertain. Link to comment Share on other sites More sharing options...
CrownChikk Posted May 22, 2025 Author Share Posted May 22, 2025 Indeed, it is diesel. I have submitted a support request to Bimmerlink and am awaiting a response. Salutations Link to comment Share on other sites More sharing options...
Kenjibb Posted May 22, 2025 Share Posted May 22, 2025 Typically, the ECU records a code for misfire. If an injector is suspected, it is advisable to examine the smooth running parameters in live data to assess the injector correction numbers, which will provide insight into the situation. Link to comment Share on other sites More sharing options...
