Mututing Posted April 8 Share Posted April 8 Greetings to everybody! Occasionally, my radio-satellite navigation equipment fails to activate. After I interrupt a circuit (by removing and reinserting the fuse or disconnecting the battery for charging), functionality is restored; but, after a few days of use, the issue reoccurs. Has anybody had a similar issue? What may be defective and need replacement? Link to comment Share on other sites More sharing options...
Captiva Posted April 8 Share Posted April 8 A often neglected detail is that the circular volume knob in the heart of the infotainment system functions as an on/off power switch. Pressing it will deactivate the infotainment system. Power cycling the device by removing the fuse will reactivate it, or alternatively, you may just click the volume button again. This button may be inadvertently activated when operating a vehicle. Clearly, there may be an alternative problem with your system; nonetheless, I recommend verifying this first. 👍 Link to comment Share on other sites More sharing options...
Mututing Posted April 8 Author Share Posted April 8 Thank you; the swap has already been checked and is not the issue. The infotainment system lacks electricity; but, after removing and reinserting the fuse, it resumes operation, allowing me to toggle it on and off using the power switch. Link to comment Share on other sites More sharing options...
Videoman Posted April 8 Share Posted April 8 Is the fuse securely positioned in the fuse holder? Have you attempted to replace the fuse? (Apologies if this is apparent, but it may well be something so straightforward.) Link to comment Share on other sites More sharing options...
Radiantecon Posted April 8 Share Posted April 8 What, no Basil jokes being presented?Wink Link to comment Share on other sites More sharing options...
Liveek Posted April 8 Share Posted April 8 ¿Qué es esto? Link to comment Share on other sites More sharing options...
Samuraisaint Posted April 8 Share Posted April 8 Refrain from referencing the conflict! Link to comment Share on other sites More sharing options...
MagicPod Posted April 8 Share Posted April 8 You initiated it! 😁 Link to comment Share on other sites More sharing options...
