AmericaMonster Posted March 28 Share Posted March 28 I own a 2006 C200 W203 with 84,000 miles on the odometer. I have had an issue with the rear tire maintaining pressure. It would decrease by around 1 pound daily. I replaced the worn rear tires with Michelin CrossClimate. To my astonishment, the offside tire continues to lose pressure. The business remounted the tire, nevertheless it continues to leak. Do alloy wheels develop porosity? Is this issue resolvable? How is that the case? Any assistance would be much appreciated. Link to comment Share on other sites More sharing options...
Captiva Posted March 28 Share Posted March 28 Compromised beading surface, undetected hairline fracture, or leaky valve...however, that should be substituted with each tire replacement. Porous wheels can occur, but seldom, and are often associated with significant bubbling and corrosion. Link to comment Share on other sites More sharing options...
Kenjibb Posted March 28 Share Posted March 28 Probable rusting on the interface surface. A refurbishment of the wheel should resolve the issue. Link to comment Share on other sites More sharing options...
AmericaMonster Posted March 28 Author Share Posted March 28 Thank you Link to comment Share on other sites More sharing options...
Shmoein Posted March 28 Share Posted March 28 I encountered this issue. The solution included eliminating any debris from the rim beads and applying a swift layer of bead sealant. Has been satisfactory for two years now. I experience little to no pressure drop between inspections. Link to comment Share on other sites More sharing options...
AmericaMonster Posted March 28 Author Share Posted March 28 Thank you. The issue is that I am reliant on specialists; I am unable to remove the tire to access the bead. I could purchase a secondhand wheel, inspect the rim and then have the tyre replaced. Link to comment Share on other sites More sharing options...
AmericaMonster Posted March 28 Author Share Posted March 28 Is it feasible to use an inner tube? Link to comment Share on other sites More sharing options...
Shmoein Posted March 28 Share Posted March 28 Any reputable tire establishment should be capable of resolving the issue for you. Link to comment Share on other sites More sharing options...
