Audi vehicles with engine modifications
tr4s
I want a trade of this kind. However, I would be grateful to have the Audi operational again with a standard engine. Interestingly, Kev has an A6 C5 equipped with a 2.5 TDI AYB 150 horsepower engine, which may be compatible provided all components are transferred from the source vehicle.
This evening, I visited an individual and his workshop, where he can rebuild my engine with whole new internals and do head skimming. Subsequently, consider a hybrid turbo, enhanced injectors, a 4-bar map sensor, a straight-through exhaust, a ported and polished cylinder head, followed by a remap.
Considering an upgrade for the clutch and dual mass flywheel.ย
Well done! The invoice for this lot is likely to be unfavourable, I presume. It seems that the modifications will result in a really fast vehicle. And boisterous, but positively so.
Eagerly anticipating the completion of this assembly.
Thank you; it will undoubtedly be worthwhile. ๐Ÿ™‚ Not pursuing excessive power, since it must remain practical for road trips and similar uses. The turbo and injectors are suitable for around 280 horsepower.
