Notef Posted July 16, 2024 Share Posted July 16, 2024 Greetings everyone, I would much appreciate any assistance. Just acquired a 2008 BMW 123d that has been remapped. Cat eliminated. I wanted to restore the vehicle to its original condition, so I installed a new catalytic converter and replaced the straight-through exhaust system. Instantly, the automobile had difficulty in starting but eventually succeeded. The car operated well, but when returning to it the next day, it failed to start. The engine cranks but fails to ignite. The device was connected and many error codes were resolved, but the technician suspected a timing problem and chose not to continue with the repairs. Do you have any suggestions or thoughts? Thank you. Link to comment Share on other sites More sharing options...
MundeDas Posted July 16, 2024 Share Posted July 16, 2024 Have you made any modifications to the mapping to fit the catalytic converter/diesel particulate filter? What is the basis for his belief that it is a matter of timing? Link to comment Share on other sites More sharing options...
Notef Posted July 16, 2024 Author Share Posted July 16, 2024 Hello, friend. Negative. The intention was for him to restore it to its original configuration, but after connecting it and examining the error codes, he concluded that there was not a problem with the file. He believed that the timing chain had been fractured. I had driven the car back from the garage where the catalytic converter was installed. Link to comment Share on other sites More sharing options...
MundeDas Posted July 16, 2024 Share Posted July 16, 2024 There is a potential occurrence on an N47 engine where the timing chain may fail abruptly. If the vehicle operated properly after the catalytic converter was installed, then the manifold absolute pressure (MAP) sensor is unlikely to be the current source of the problem. Remove the cam sensor and manually rotate the engine to see whether the cam moves. whether it does, ask someone to synchronise the timing and ensure that it is properly aligned. Link to comment Share on other sites More sharing options...
Notef Posted July 16, 2024 Author Share Posted July 16, 2024 Thank you. Upon fitting the cat, the individual saw that it was experiencing excessive turnover before to commencing. Entered abruptly beforehand. The car had previously been equipped with a timing chain. The vehicle operated well from the garage to its destination at home. I have parked my vehicle and it is now not functioning or starting. Will the chain not be broken for certain? I am uncertain whether these are outdated codes, however I had the following codes... Neutral position, calibration BSD notification The preheating control device is absent. Heating and activation of the fuel filter Activation of the oxygen sensor heater The camshaft sensor detects and transmits the signal related to the position of the camshaft. Link to comment Share on other sites More sharing options...
MundeDas Posted July 16, 2024 Share Posted July 16, 2024 The camshaft sensor signal is crucial, and it might indeed fail suddenly. Chains experience the greatest amount of stress when they come to a halt and start again, therefore this might have been the last contributing factor. Remove the cam sensor. I believe that if you manually rotate the crankshaft, you will discover that the camshaft does not rotate. Link to comment Share on other sites More sharing options...
Syncephe Posted July 16, 2024 Share Posted July 16, 2024 I agree with the above statement. Link to comment Share on other sites More sharing options...
Notef Posted July 16, 2024 Author Share Posted July 16, 2024 Thank you. Are we considering the possibility of a timing chain issue or a faulty camshaft sensor? Link to comment Share on other sites More sharing options...
MundeDas Posted July 16, 2024 Share Posted July 16, 2024 A timing chain is a mechanical device used in internal combustion engines to synchronise the rotation of the crankshaft and the camshaft. Link to comment Share on other sites More sharing options...
Syncephe Posted July 16, 2024 Share Posted July 16, 2024 You are removing the sensor to visually inspect if the cam is being rotated by the chain inside its designated cavity. Link to comment Share on other sites More sharing options...
Notef Posted July 16, 2024 Author Share Posted July 16, 2024 Everything has been organised and arranged. The camshaft sensor's connection was damaged. Consequently, it had gradually detached itself to the point where there was no beginning. Exhale! Link to comment Share on other sites More sharing options...
Syncephe Posted July 16, 2024 Share Posted July 16, 2024 I'm pleased that you were able to find the solution. Link to comment Share on other sites More sharing options...
