Is there a plastic "plug" available for the emblem?
OmahaKnot
The model of the car is SL400 from the year 2015.
I am in the process of repairing the front emblem, but, I have seen the absence of the plastic "plugs" in the holes on my vehicle. I attempted to attach it using double sided adhesive, but, it is unstable due to the absence of support on the lower portion (as seen in the picture, resembling a smiling face). Could you provide guidance on the specific locations where I may get these items and the precise terminology used to refer to them? Greetings
Alternate model displaying plastic "plugs" inside the apertures:
Is there any obstruction preventing the badge from being positioned correctly? Have you conducted a comparison of the undersides of both the new and old badges? Did the previous emblem remain in the same position and move back and forth?
I did not get the previous badge that was removed for stone chip repairs at the bodyshop, and I am uncertain about its condition prior to the repairs. The emblem is an original equipment manufacturer (OEM) part and its intended placement on the vehicle is visible. However, there seems to be a significant gap underneath the two holes on the car's body, which raises concerns about the lack of support for the lower portion of the badge.
Alternatively, you may get a suitable thickness of adhesive double-sided foam and apply it underneath the middle of the insignia to further enhance its stability. Undesirable are 50,000 miles of unstable movement, causing damage to the paint and resulting in a corroded bonnet that requires repairs. Given your knowledge of your obsessive-compulsive disorder, Slarti, I am certain that you are contemplating this.
