Bleakerje Posted May 22, 2024 Share Posted May 22, 2024 Greetings, everyone. The service light on our Kia Picanto illuminated a few days ago. The codes suggest a potential problem with the CMP (Camshaft Position) sensor. Where is the CMP located on this? I presume it is positioned on the rear near the rocker, as indicated by the label "exhaust". Is it sufficiently straightforward to replace? ================================= OBD-II DTCs: 2 ---------------------------- P0340 [0x0340] The camshaft position (CMP) sensor A, bank 1 is experiencing a problem in its circuit. Confirmation received. Code P0014 The hexadecimal value [0x0014] represents a specific memory address or data value. The exhaust/right/rear camshaft position (CMP) actuator in bank 1 is experiencing timing over-advanced and system performance issues. Status: Awaiting resolution ============================ Electronic control moduleEngine control unit Diagnostic Trouble Codes: 2 ---------------------------- P0014 The hexadecimal value [0x0014] represents a specific memory address or data value. The exhaust/right/rear camshaft position (CMP) actuator in bank 1 is experiencing timing over-advanced and system performance issues. Status: The issue was confirmed to be existent at the time of the request. ---------------------------- The error code P0340 [0x0340] is displayed. The circuit for the Camshaft Position (CMP) sensor A on bank 1 is experiencing a problem. Status: Confirmed and saved in permanent memory. Confirmed fault detected at the time of the request. Confirmed fault has been present throughout this drive cycle. ============================ Transmission control unitThe gearbox control unit has detected 2 diagnostic trouble codes (DTCs). One of the codes is P0014 [0x0014]. The exhaust/right/rear camshaft position (CMP) actuator on bank 1 is experiencing timing over-advanced or system performance issues. Status: Fault confirmed at the time of the request. ---------------------------- Error code P0340 [0x0340] The circuit for the camshaft position (CMP) sensor A on bank 1 is experiencing a problem. Status: Confirmed and stored in permanent memory, Confirmed fault detected at the time of the request, Confirmed fault has been present throughout this driving cycle Is it located under the air filter housing? Link to comment Share on other sites More sharing options...
Lovelyas Posted May 22, 2024 Share Posted May 22, 2024 Transferred from the section on instructional manuals. This is not a comprehensive, detailed guide as indicated by the stickies. Link to comment Share on other sites More sharing options...
engrol Posted May 22, 2024 Share Posted May 22, 2024 Perform an initial deletion and see whether it reappears before making any changes, since they often emerge without any apparent cause. If you need to replace it, ensure that you choose an authentic Kia component. Due to the lack of compatibility, Kia and Hyundai vehicles often do not function properly with Pat components. Link to comment Share on other sites More sharing options...
Bleakerje Posted May 22, 2024 Author Share Posted May 22, 2024 Thank you. I will provide a concise explanation. Does the image correspond to the proper sensor? Link to comment Share on other sites More sharing options...
engrol Posted May 22, 2024 Share Posted May 22, 2024 This hyperlink including videos could be beneficial to you. The position of the camshaft sensor in the 2011 Picanto may be found by doing a search on Google. Link to comment Share on other sites More sharing options...
Bleakerje Posted May 22, 2024 Author Share Posted May 22, 2024 This is a second generation model from 2011. I suppose the videos are of the first generation. Link to comment Share on other sites More sharing options...
Bleakerje Posted May 22, 2024 Author Share Posted May 22, 2024 Apologies. I apologise for any confusion in my previous message. The vehicle in question is a 2011 mk2 model. I believe the videos are of mediocre quality. Link to comment Share on other sites More sharing options...
Bleakerje Posted May 22, 2024 Author Share Posted May 22, 2024 Returned promptly after a brief excursion 😞 Link to comment Share on other sites More sharing options...
