engrol Posted 23 minutes ago Share Posted 23 minutes ago Except for the fastest setting, which lasts about two seconds, all of my intermittent wiper speeds have disappeared. I used to be able to get by with around six different settings and a delay of around ten seconds. Remove the wipers by twisting the collar. If this is indeed a UCH function, then I'm completely stumped; what are the team's thoughts on the matter? Correction: it works, but there are absurdly long delays of twenty to thirty seconds. The 'long' setting exhibited a tantrum at intervals of 2-4 seconds as well. Link to comment Share on other sites More sharing options...
engrol Posted 23 minutes ago Author Share Posted 23 minutes ago https://www.amazon.com/s?ascsubtag=v1-2d4aab-621676-6c2d34e34d-k&k=Renault+Scenic+3+UCH Link to comment Share on other sites More sharing options...
DownContent Posted 20 minutes ago Share Posted 20 minutes ago This is just a wild speculation, but has the wiper stalk finally given up? Link to comment Share on other sites More sharing options...
engrol Posted 20 minutes ago Author Share Posted 20 minutes ago If it weren't for the regular timing of the functioning settings, I might suspect stalking. Inconsistent, but useless. Additionally, it has occurred in the intervals between various outings. There is no shadiness, no "sometimes it works, sometimes it doesn't," just what worked before and isn't working now. As if it were mistakenly keeping track of the intervals between wipes. It has been stored in the garage for the past eight years, so I doubt there are any issues with water. It's just the stalk and the UCH because there is absolutely no wiper relay. At least the stalk isn't a pricey parts dart. Link to comment Share on other sites More sharing options...
engrol Posted 19 minutes ago Author Share Posted 19 minutes ago https://www.amazon.com/s?ascsubtag=v1-2d4aab-621676-6c2d34e34d-k&k=Renault+Scenic+3+UCH Link to comment Share on other sites More sharing options...
DownContent Posted 18 minutes ago Share Posted 18 minutes ago Because they don't leave any evidence, problems like these are extremely confusing. Oh, I see. :rolleyes: But why, though? Link to comment Share on other sites More sharing options...
Talentrews Posted 17 minutes ago Share Posted 17 minutes ago Received this from Gemini. I think it's worth a shot as a substitute stalker. The UCH (UnitĂ© Centrale HĂ´ro-habitacle, or Body Control Module) processes signals from the wiper stalk switch and the rain sensor (if installed) to regulate the intermittent wipe function on the Renault Laguna Mk2. On the steering wheel, you'll find the Stalk, which transmits signals for position and adjustment rings and serves as the actual user input device. • The UCH: Takes all of these readings, handles the timing of the intervals, and turns on the wiper motor relay. Common causes of intermittent wiping failure with continuous high or low speeds functioning normally include a broken wiper stalk switch, a malfunctioning relay or motor ground, or an issue with water intrusion in the UCH unit. Link to comment Share on other sites More sharing options...
engrol Posted 17 minutes ago Author Share Posted 17 minutes ago Considering that aspect, so long as I am spared the task of removing the steering wheel, as Haynes suggests. I have a feeling it's not the classic resistor kind, but I'll give an IPA wash a go first. It would be great if you could tell me if the timing was coming from the stalk circuit or the UCH/ECU. Any other ideas? Link to comment Share on other sites More sharing options...
DownContent Posted 16 minutes ago Share Posted 16 minutes ago The connector appears to have thirteen pins and three wires. I have no idea what the contents of the small box containing the brass tracks could be. Link to comment Share on other sites More sharing options...
DownContent Posted 16 minutes ago Share Posted 16 minutes ago https://go.skimresources.com/?id=130832X1595746&isjs=1&jv=15.7.1&sref=https%3A%2F%2F Link to comment Share on other sites More sharing options...
engrol Posted 15 minutes ago Author Share Posted 15 minutes ago Seems like it's a replacement; I'll go ahead and buy a new one before taking a look at the old one. Coming back to you soon. Some of you know how long it takes me to get around to it, so it might be a while. We don't drive very often, and even less so in the rain. Link to comment Share on other sites More sharing options...
